October 08, 2025, 05:26:18 PM *
Author Topic: Longer oil filter  (Read 1887 times)
Clarkkent
« on: January 30, 2019, 01:52:47 PM »
 I'm looking for the number for the longer oil filter for the 1500.
I know the short filter is 6607.
Thanks  in advance.  CK.
« Reply #1 on: January 30, 2019, 02:32:01 PM »
I'm pretty sure that is a Purolator Pure One filter.
But the part number escapes me.
I don't know if it listed in Jeff K's Generic Valkyrie Parts Page in Shoptalk.
ccscootlund
« Reply #2 on: January 30, 2019, 02:57:26 PM »
hey Clark... I run a Purolator Boss # PBL14610
The Purolator One is PL14610
indybobm
Franklin, Indiana VRCC # 5258
« Reply #3 on: January 30, 2019, 02:59:26 PM »
I use a Purolater PL14610 filter
So many roads, so little time
VRCC # 5258
Andy Cote
Windham, Maine
« Reply #4 on: January 30, 2019, 03:56:43 PM »
Apologize for length of post but...…
This article was written by Mike Guillory.
Technical Fitment Specification
20 X 1.5mm threads, gasket diameter approximately 2.3 inches, O.D. approx. 2.75 inches, length approximately 2.5 to 3.5 inches.
__________
OEM Motorcycle Oil Filters
You can't go wrong using the OEM filter for your motorcycle. However, sometimes these may be hard to find, especially on a Sunday or Monday, or in smaller communities, or you may think the OEM part is unnecessarily expensive. Or, you may want a better filter to further minimize engine wear. You deserve choices.
Alternate Motorcycle Oil Filters
If your motorcycle uses the Honda 15410-MM9-013 oil filter (most late model VFRs, CBRs, ST1100s, etc), following are some filters which are equivalent to and possibly superior to the Honda filter. These also fit most late-model Kawasaki sportbikes and Vulcans, plus most late-model Yamaha sportbikes, the VMAX, and the Royal Star. They also can be used on the mid-80s Magnas, Sabres, Interceptors, and Shadows. See Author's note #6, below for a comment about Suzuki oil filters.
Important: The only meaningful difference between all those shown below are external length. They all fit the 1994 to 1997 VFR, the CBR600s, and mid-80s Magnas and Sabres. Your motorcycle's clearance and available space for a spin-on filter may be different, so you need to consider that. The very shortest filters should fit anywhere. All threads and gasket dimensions are compatible, all have anti-drain back valves, and all have bypass valves that operate in the normal range of 8 to 13 psi range.
Motorcycle-Specific Filters - (About 2.5 to 3 inches long)
1.   Purolator Motorcycle ML16817
2.   NAPA Gold 1358, Carquest 85358, WIX 51358
3.   AC Delco PF2135
4.   FRAM PH6017A
5.   K&N KN-204
6.   AMSOil SMF103
7.   Honda 15410-MCJ-000
8.   STP SMO 17
Automobile Filters - (About 3.5 inches long - fit reference 1994 Mazda MX-3, V-6 Engine)
1.   Mobil 1 M1-110
2.   Bosch 3323 about
3.   Purolator Pure One L14620
4.   NAPA Gold 1356
5.   Carquest 85356
6.   WIX 51356
7.   Deutsch D-370
8.   AC Delco PF-2057
9.   Motorcraft Long Life FL-821 or FL-822 (?)
10.   STP S-02867
11.   FRAM, Castrol, Penske & Wal-Mart Super Tech 7317
12.   K&N HP1010 (?)
13.   Auto Pro 2356
14.   Autopride CF240AP
15.   Baldwin B1402
16.   Carquest Red B4620
17.   Casite CF240
18.   Champion Labs Ph2867
19.   Defense Filters Dl7317
20.   Federated Filters LF240F
21.   Group 7 V4610
22.   Group 7 V4620
23.   Hastings LF240
24.   Mighty M4612
25.   Parts Plus PH2867
26.   Pennzoil PZ-109
27.   Penske 7317
28.   Powerflo SL14610
29.   Powerflo SL14620
30.   Pro Gauge PGO-4620
31.   Pro Tec 164
32.   Promotive PH4610
33.   Pronto PO3593A
34.   Service Champ OF-4622
35.   Shell SH48
36.   Shell SH529
37.   Stp S-02867.
38.   Valvoline VO50
39.   Warner PH2867
40.   Wix 51356
Automobile Filters - (About 2.5 inches long - fit reference Mazda RX-7 and Miata)
1.   Mobil 1 M1-108
2.   Bosch 3300
3.   NAPA Gold 1365
4.   Purolator L14622
5.   AC Delco PF1237
6.   STP S-0287
7.   FRAM PH6607
8.   WalMart SuperTech ST6607
9.   Baldwin B1400
10.   Firestone TF2876
11.   Hastings LF113
2015 Goldwing, basic black
Previously: 2000 Valkyrie Interstate, 1997 Valkyrie Standard, 1988 GL1500, GL1200 Standard, GL1200 Interstate and many other Hondas
scarylarry
wis rapids, wi
« Reply #5 on: January 30, 2019, 09:26:48 PM »
I run the Mobil-1 M1-110..walmart has them and they come in black
« Reply #6 on: January 31, 2019, 05:27:43 AM »
I use an oversized PureOne PL14459. larger dia, more filter media, same length as OEM.
be careful with a longer filter. some were cut open yrs ago and it was found that the filter media was same length as the shorter one.
h13man
Indiana NW Central Flatlands
« Reply #7 on: January 31, 2019, 06:36:33 AM »
Bosch 3323. Been running them since the original Walmart Supertech line was discontinued.
« Reply #8 on: January 31, 2019, 07:33:12 PM »
I use a Purolater PL14610 filter.  They even make them in BLUE!!!
HayHauler Cool
RWhitehouse
« Reply #9 on: February 01, 2019, 07:36:00 AM »
For Wix/Napa (same thing)
1356- this is the ~3.25" long "car" filter.
1358- this is the "motorcycle" filter. About 2.5" long. Instead of six (iirc) larger holes like the 56/65, this one has eight smaller ones
1365- This is the 2.5" long "car" filter.
All three will fit virtually any motorcycle that takes a spin-on.
Napa Gold is the same as Wix Regular. Napa platinum is the same as a Wix "XP".  On Wix-branded boxes, there's another number in front of the four digit code, which just refers to the economy/regular/premium level.
I've used all three. My Vmax had an oil pressure gauge, and I did notice it tended to be a bit lower using the longer 1356- less restriction from bigger filter, so not surprising. The 1358/1365 were about the same, and across the board a few psi higher. Maybe like 33 vs 30 psi at the same highway RPM. Not a huge difference. Both idled around 2-3psi, which was typical for the bike. High volume, lower pressure system.
I go for the 1356 just for a bigger surface area. They go on sale at napa couple times a year for like half off, so I grab a half dozen or so when I happen to catch it, or when they do the thing where you buy the bucket for a dollar and it's half off whatever you can fit in it. You can get about a dozen oil filters in it. lol
« Reply #10 on: February 01, 2019, 08:10:05 AM »
When trying to get the whole gallon in, it's better to have the longer filter.
This sounds vaguely obscene, but it's not.
Gideon
Indianapolis, IN.
« Reply #11 on: February 01, 2019, 08:50:57 AM »
cooldude:
I also use the whole gallon with a PureOne PL14610 Filter. It's not obscene, it's a good and convenient thing.  Smiley
mello dude
Dayton Ohio
« Reply #12 on: February 01, 2019, 04:11:58 PM »
Link to filter website....
http://www.calsci.com/motorcycleinfo/FilterXRef.html
Clarkkent
« Reply #13 on: February 16, 2019, 09:13:37 AM »
WOW!  THANKS TO ALL.     WHAT A  GROUP.  (YOU MEET THE NICEST PEOPLE ON VALKYRIES)   cooldude
I NOW HAVE ALL THE FILTER CHOICES I NEED.  (AND I HAVE 2 MONTHS) TO FIGURE OUT WHICH ONE TO USE! 2funny   ie:  we still have 24" of snow in the driveway!
« Last Edit: February 16, 2019, 09:15:52 AM by Clarkkent » Logged
