November 14, 2025, 03:34:06 AM
Best rebuild kits
Topic: Best rebuild kits (Read 1112 times)
PatrickDoss
Alabama
Best rebuild kits
February 11, 2019, 08:08:36 PM »
Hi all, looking for info on the best (quality) rebuild kits for both the OEM petcock and clutch slave cylinders. I have a petcock with an unknown history and a clutch slave with some clear-ish gel I assume is old brake fluid built up around it. Thanks in advance.
Re: Best rebuild kits
February 12, 2019, 06:39:41 AM »
Buy OEM units at Partzilla.com.
February 12, 2019, 06:46:33 AM »
Quote from: sandy on February 12, 2019, 06:39:41 AM
mark81
Cincinnati Ohio
February 12, 2019, 07:03:00 AM »
My personal experience: I used oem cover set to rebuild my petcock. 2 years later it still works I was skeptical about it because I drove over an hour to the closest Honda dealer that had one in stock. It looked to be sitting on the shelf for the last 20 years. It’s still holding though. When I rebuilt my clutch slave a few months later I used the K&L kit on the recommendation of big papa pump. It’s still working fine with no leaks too.
1997 Honda Valkyrie
1981 Honda CB750 Custom
PatrickDoss
Alabama
February 12, 2019, 08:02:07 PM »
So, what do I get? Number 5 in the diagram under fuel tank?
https://www.partzilla.com/catalog/honda/motorcycle/2000/gl1500cf-a-valkyrie-interstate/fuel-tank
Sorry I can't attach a pic to keep you from having to go look it up.
February 13, 2019, 03:52:05 AM »
Quote from: PatrickDoss on February 12, 2019, 08:02:07 PM
Right, #5, the cover set, rebuilds your petcock. I like to get #4 (screen) too...
=> InZane XXV
