January 30, 2026, 02:06:32 AM *
Author Topic: Planning a petcock rebuild / air filter element / vacuum line wrench party  (Read 2566 times)
Disco
Republic of Texas
« on: November 21, 2009, 09:57:49 AM »
I have the cover set and air filter element but was wondering if someone can spec the vacuum line so I can buy it in bulk for multiple bikes.  Is there something out there better than the OEM?  About how many feet of vacuum line does one Valkyrie require?
TIA,
DFG
« Last Edit: November 21, 2009, 10:05:54 AM by Dave in Frisco (TX) » Logged
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
« Reply #1 on: November 21, 2009, 12:23:01 PM »
Dave: First: It's good to hear your feeling well enough to work on bikes again. 2nd: I've found nothing better than OEM vacuum lines. Silicone can get brittle in the heat and NAPA stuff will crack in 6-12 months. HDL sells 26 ft (1000 mm I think) for about $41 with handling charge($1.50/ft). About 3.5 - 4 ft will do the pair valve lines and petcock line. I replaced mine with OEM from HDL 3 yrs ago. No problems with 110K on the ODO.
Disco
Republic of Texas
« Reply #2 on: November 22, 2009, 05:40:01 AM »
Thanks, Sandy.  I'm planning the DFW VRCC December wrench party and expect to have quite a few bikes there.
Off-topic, but...  Hospital for 2 days, Walkyrie for 3 weeks, Cane for 3 weeks but began tapering off about 1.5 weeks in.  At event + 44 days, the Doc said, "Lose the cane".  Back on the Rumblebee at event + 48 days.
http://www.valkyrieforum.com/bbs/index.php/topic,10561.0.html
78 CB550K
Madmike
Campbell River BC, Canada
« Reply #3 on: November 23, 2009, 04:56:11 PM »
HDL sells 26 ft (1000 mm I think) for about $41 with handling charge($1.50/ft). About 3.5 - 4 ft will do the pair valve lines and petcock line......
for those that don't deal with the metric system on a daily basis........1000 mm is 1 meter  is 39.36 inches.........  Smiley Smiley
Disco
Republic of Texas
« Reply #4 on: November 23, 2009, 05:47:19 PM »
Thanks, Mike.  I skipped right over and didn't catch the mm and focused on the ft.
78 CB550K
« Reply #5 on: November 24, 2009, 05:19:13 PM »
TIA,
DFG
hypalon caps  sold by jegs. Have never seen solid hypalon tubing, always seams to be used as a liner.
viton tubing
http://www.acmerubber.com/vittube.htm
there are many other sites and the best materials to use on engines.
