December 31, 2025, 06:11:40 PM *
Author Topic: final drive  (Read 956 times)
jackt
This is one of my babies
Central Kansas
« on: March 16, 2019, 04:56:15 AM »
Is the Gold Wing 1994 to 2000 pumpkin final drive the same as the 97 to 03 as the Valkryie?
A direct swap???
Jack
just waiting on some warm weather in Kansas
2006 Shadow
1999 Standard (fast black)
1997 Bumblebee
2005 Gold Wing trike
« Reply #1 on: March 16, 2019, 06:27:27 AM »
           While I am personally Not sure Grumpy in Florida Knows. I believe the gear sets are similar if not the same BUT have to be pressed out of the G/W pumpkin and then-after Valkyrie gear set removal-pressed into the Valkyrie pumpkin. Again-I am NOT Sure so git hold of Grumpy. Probably best trying the Florida board. RIDE SAFE.
« Reply #2 on: March 16, 2019, 06:43:25 AM »
The housings ae not interchangeable. One of the 4 mounting studs is out of place. Some of the internal gears and bearings can be exchanged.
« Last Edit: March 16, 2019, 06:46:10 AM by sandy » Logged
« Reply #3 on: March 16, 2019, 07:07:28 AM »
A direct swap???
Jack
use search function.  many posts what parts fit and what doesn't. there are also posts about fitting the goldwing swingarm with the final drive
Avanti
Stoughton, Wisconsin
« Reply #4 on: March 16, 2019, 03:59:07 PM »
Start here:
http://www.valkyrieforum.com/bbs/index.php/topic,48990.0.html
« Reply #5 on: March 16, 2019, 04:54:19 PM »
No. But had heard that if you swap the swing arms, it may fit.
« Reply #6 on: March 17, 2019, 09:51:53 AM »
The server at Clemson where I had my pictures posted was allowed to disappear  :'( ...
I've just rehosted them at Google, and they show up again...
