December 28, 2025, 07:32:47 AM *
Author Topic: Polk Db 501  (Read 3537 times)
NighthawkVTX
Gainesville, Fl
« on: April 14, 2019, 12:51:07 PM »
Just to confirm  the db 501 is the speaker that directly replaces the front stock speaker in the IS?
Is it worth changing it out?
Also I was thinking of adding an amp and maybe a small subwoofer to add some bass. Nothing stupid to shake the parts off. Just something to add some richness to the sound
 Anyone have any thoughts, better yet pics?
If at first you don't succeed, then perhaps skydiving isn't for you
« Reply #1 on: April 14, 2019, 01:38:15 PM »
You have the how-to? Here's one.
http://forums.delphiforums.com/valkyrie/messages?msg=12890.1&gid=2139266887
The speakers are 5". The OEM are 4". I thought that the Polk wasn't being made any more?
I put a set in my trunk, placed that on my Shadow ACE Tourer, and installed a marine radio. Sound could never get loud enough to hear going down the hwy at 70mph from the back.
markymark640
Augusta Georgia
« Reply #2 on: April 14, 2019, 02:18:51 PM »
I did the db501's front and back on my Interstate, and added an amplifier inside the fairing. It rocks, plenty loud enough to hear even at highway speeds. In city about 17, on the highway about 23 on the volume control rocking the tunes.  Well worth the investment if you ask me. I plug my iPhone in on the AUX and play tunes from it.  Crank the volume up on the phone and it's even louder.
Jersey
VRCC #37540
Southern Maryland
« Reply #3 on: April 14, 2019, 03:03:53 PM »
I did the same as Mark... 501's in front and back with amp in the fairing. The front is a direct fit. The rear ones you'll need to trim about an 1/8" of the metal off on the one side of the speaker mounting plate. Easily done with tin snips. Sound much better!
« Last Edit: April 15, 2019, 06:35:43 AM by Jersey » Logged
Jersey
« Reply #4 on: April 14, 2019, 06:53:29 PM »
The DB 501's are no longer made. A few years ago, I replaced my '05 wing speakers with the 501's. A great improvement.
Jim in Idaho
« Reply #5 on: April 15, 2019, 06:06:24 AM »
Now produced as a DB522
Polk Audio DB522 DB 5.25 inch (DB 522)
https://www.sonicelectronix.com/item_112175_Polk-Audio-DB522-DB-5.25-inch-DB-522.html
lots of the old series still found NOS on ebay though if you must have the DB501
https://www.ebay.com/itm/POLK-AUDIO-DB501-5-CAR-BOAT-MOTORCYCLE-MARINE-AUDIO-2-WAY-SPEAKERS-PAIR/273671174669?epid=69744703&hash=item3fb812ba0d:g:JsYAAOSwDNdVuBG8:sc:ShippingMethodExpress!83709!US!-1
« Last Edit: April 15, 2019, 06:09:03 AM by Jim in Idaho » Logged
Jersey
VRCC #37540
Southern Maryland
« Reply #6 on: April 15, 2019, 06:42:12 AM »
Has anyone installed the DB522's on the Interstate?  Do they fit or is a modification needed?
Jersey
« Reply #7 on: April 15, 2019, 09:09:36 AM »
If they are the same size as the 501's they'll fit.  Even the 501s had to be slightly modified to fit.
« Reply #8 on: April 15, 2019, 04:14:39 PM »
The stock speaker is a 4". The Polk 501 was 5". The link I posted showed how to make the larger speak fit. The same can be done with the mentioned 522 5.25" speaker too.
Any marine (outdoor) speaker of the right size can be used.
SCain
Rio Rancho, NM
« Reply #9 on: April 16, 2019, 07:00:58 AM »
Guys, the DB501 speakers are still available on Amazon, not sure how many sets are still available but after people see this they will be gone. They are $60.
Steve
Paladin528
« Reply #10 on: April 24, 2019, 09:11:09 AM »
The DB501 was superceded by the DB522.
I have the DB501 in the front and the DB401 in the trunk.  No modification necessary.
I have a Clarion Amp under the fairing to drive them and it sounds FAR better than stock.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #11 on: April 25, 2019, 02:14:51 PM »
I put a 240 watt amp from Electrical Connections in the fairing ... several years ago, and 2-way Alpine speakers front and back.  Got rid of those stupid speaker enclosures in the fairing and lined every inch of the inside of the fairing and backsides of the speaker panels with DynaMat.  And if you knock on the fairing with your knuckles, it sounds solid, not hollow.  I can hear mine fine at #7 on the highway with Mark T glasspacks.
States I Have Ridden In
Joe333x
Boston
« Reply #12 on: November 15, 2023, 06:47:38 PM »
I tried the 522 today, it is too big and will not line up with the mounting holes unfortunately. I'm going to have to try the DB402 since the 501 is discontinued.
