December 31, 2025, 04:41:11 PM *
Author Topic: One piece seat question  (Read 997 times)
NighthawkVTX
Gainesville, Fl
« on: April 30, 2019, 06:47:19 AM »
Does the 99 tourer have the same one piece seat as the IS?
If at first you don't succeed, then perhaps skydiving isn't for you
JimC
SE Wisconsin
« Reply #1 on: April 30, 2019, 07:02:07 AM »
No,
it would be two piece, same as the standard model.
Jim
Jim Callaghan    SE Wisconsin
« Reply #2 on: April 30, 2019, 08:03:45 PM »
The IS has a larger gas tank, therefore the seat is a little shorter in length. They are ALL interchangeable. Some would fit better, you might need to do something with a non-IS seat on an IS. I believe the std/tourer has a bolt in the back to hold it on, but then the IS uses a tab, and my tab was cut off the trunk by a PO.
« Reply #3 on: April 30, 2019, 10:33:24 PM »
As above, no but a stock IS dual tour can probably be made to fit (though there may be some space at the nose).  And most aftermarket Tourer seats are also 2-piece.  But aftermarket dual tour seats for Std/Tourer are made by Corbin (concrete) and Saddlemen.
Paladin528
« Reply #4 on: May 01, 2019, 04:43:09 AM »
I have a solo seat from a standard that I put on my IS when the Trunk is removed.  Fitment is good
« Reply #5 on: May 01, 2019, 07:12:14 AM »
Common misconception.  The additional room in the Interstate tank is in rise, not length.  The tanks are the same length.  The nose of the Interstate saddle does not slope forward as does the Standard saddle because the rear of the tank doesn't slope forward at such a shallow angle.
Putting a (post 2000) Standard saddle on an Interstate will likely scrunch the nose bit it will fit.  Taking a bit of the padding from the nose will remedy that.
