December 31, 2025, 04:39:33 PM *
Author Topic: air filter causes bike to stall ?  (Read 1235 times)
manybikes
« on: May 03, 2019, 11:58:09 PM »
Just rebuilt carbs work great except when I when I install air filter or air box cover bike stalls?
Avanti
Stoughton, Wisconsin
« Reply #1 on: May 04, 2019, 02:34:01 AM »
What is the Idle RPM set at? Will it start back up with the throttle opened a small amount or using the enricher (choke) ? Is the air box cover inlet clear?
Need to narrow it down to air, fuel, or electrical.
« Last Edit: May 04, 2019, 02:38:18 AM by Avanti » Logged
Pete
« Reply #2 on: May 04, 2019, 02:47:10 AM »
Old filter/new filter? Idle RPM? Low speed jet settings? Are those low speed jets really clean? Vacuum Leak?
manybikes
« Reply #3 on: May 04, 2019, 06:57:38 AM »
All six pipes going into manifold are plugged idle speed set at 1000 bike will only restart if I remove air cleaner pilot jet very clean can see gas coming out of small three holes
Lyle Laun
Calgary, Ab
« Reply #4 on: May 04, 2019, 07:16:22 AM »
Is that a freshly oiled K&N air filter ?
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
Pete
« Reply #5 on: May 04, 2019, 02:07:36 PM »
Old filter/new filter?  Low speed jet settings(1 3/4 to 2 1/4)?  Vacuum Leak other than plugged / orings ?
The low speed jet is 1 single hole.
pancho
Bonanza Arkansas
« Reply #6 on: May 05, 2019, 11:09:15 AM »
Sounds like you may be running way too rich,, do you smell gas when running?  If you don't have a clogged up air filter, you might need to look into those carbs again, see if something was done wrong.
Dusty
Mill Bay B.C.
« Reply #7 on: May 05, 2019, 06:49:39 PM »
Had the same problem and  the freshly cleaned and oiled K and N filter would not let enough air through.   It had too much oii in it. Rewashed and less oil and it worked fine.
I also changed  an OEM Valkyrie air filter  for a fellow that had 100,000 kilometers on it. It was filthy black but the bike still ran.
Dusty
