December 31, 2025, 04:23:21 PM *
Author Topic: Loss of Clutch Hydraulics?  (Read 1181 times)
mikeirion
Frankenmuth, MI
« on: May 05, 2019, 06:31:38 PM »
So I put the 97 Valk in the barn last fall and everything was fine. Pulled her out this week, she fired right up, pulled in the clutch and put it in first gear and it lurched forward and stalled. I then realized that the clutch lever was real weak like there was no hydraulic pressure, it pulled all the way back to the grip. What do you think happened over the winter? The fluid in the reservoir was down a little but not real low.
2000 Interstate
1997 Standard Modified
« Reply #1 on: May 05, 2019, 06:49:27 PM »
Change the fluid and bleed it well. I will bet you will be good to go.
pancho
Bonanza Arkansas
« Reply #2 on: May 06, 2019, 04:23:04 AM »
Take a look under the bike and see if your slave cylinder is leaking. It will ruin the paint job on the rear cover.
« Last Edit: May 06, 2019, 04:34:17 AM by pancho » Logged
« Reply #3 on: May 06, 2019, 04:12:51 PM »
The clutch pack dries out, and needs to get fluid onto again.
I would idle the bike for a while over the day, and work the clutch handle, and see how it is tomorrow.
Changing the fluid (checking the level) is something that may need doing.
DIGGER
« Reply #4 on: May 09, 2019, 11:08:03 AM »
What hydraulic fluid for clutch reservoir?
« Reply #5 on: May 09, 2019, 11:36:57 AM »
DOT 4 brake fluid. If you've never changed your fluid, I'm sure it's going to be nasty. Be prepared to clean out your reservoirs.
mello dude
Dayton Ohio
« Reply #6 on: May 09, 2019, 01:21:43 PM »
I like the Valvoline Syn Dot 4 fluid. .. And the point on cleaning the reservoirs.  I have a dedicated turkey baster to suck out all the fluid in the brake and clutch reservoirs. After that, take a paper towel and wipe the interior good. Then next, Qtip the corners as there still will be gunk stuck there.  Refill with clean and bleed from there. -- Its easier this way as opposed to flush bad fluid thru the system.  Cool
« Reply #7 on: May 09, 2019, 01:30:23 PM »
Great minds think alike  cooldude
Savage
United States
« Reply #8 on: May 09, 2019, 07:04:38 PM »
+1 on checking clutch slave. Had mine go out in Los Angeles traffic and had to flatbed the bike home. I keep a clutch slave cylinder rebuild kit in my saddlebag when i tour now.
Columbia, South Carolina
