December 31, 2025, 02:39:52 PM *
Author Topic: In Line fuel Filter or none at al??l  (Read 1250 times)
Spurs
Summerfield, FL
« on: May 22, 2019, 10:38:13 AM »
had bad gas in my '99 IS and am wondering is there a fuel filter on our machines??
Gary
1997 Valk Std
2014 Indian Vintage
2016 Polaris Slingshot
Politicians and diapers need to be changed often and for the same reason. Mark Twain
« Reply #1 on: May 22, 2019, 10:57:38 AM »
Gary
There is a fuel screen that is the only "filter" on a stock bike.  Its attached to the petcock and you cant see it because its up inside the tank.  These bikes have millions of miles with just using this screen filter, I wouldnt worry too much.  It seems more people have issues with modifications to the fuel lines to run additional filters and quick releases.
Paladin528
« Reply #2 on: May 23, 2019, 10:29:18 AM »
PO had installed a filter on my ride.  I removed it in short order.
Spurs
Summerfield, FL
« Reply #3 on: May 24, 2019, 09:19:36 AM »
Thank you
1997 Valk Std
2014 Indian Vintage
Savage
United States
« Reply #4 on: May 24, 2019, 12:10:46 PM »
My past experience:
1. Inline fuel filter... caused a shortage of fuel to the carbs.
2. Quick detach in the fuel line...  caused a shortage of fuel to the carbs.
3. Dan Marc fuel shutoff... I removed this when I removed the quick detach. Not sure whether or not it contributed to fuel supply issues but plan to try it at a later date without the QD and see how it performs.
Columbia, South Carolina
« Reply #5 on: May 24, 2019, 12:24:03 PM »
Well....FWIW, I've been running an inline filter and Dan Marc shutoff for close to 15 yrs. w/o any issues. Only problem I have when touring is the I/S tank, it seems to run low after about 200 miles.  Roll Eyes Wink
RWhitehouse
« Reply #6 on: May 24, 2019, 01:09:47 PM »
I used a generic 3/8" inline filter from napa before the tee to the left/right carb banks. Bike came to me already with a manual Pingel petcock. Necessary? Probably not. But I had the rack off to replace the float needles as one was getting incontinent, and the original hoses didn't seem in the greatest shape so replaced everything. The screen on the petcock is just that, it'll keep the rocks and marbles out but that's about it. Figured that an actual filter couldn't hurt, especially since stuck/leaking needle on these bikes has a decent chance of leading to a hydrolock.
It has absolutely zero fuel delivery issues, something I've tested by holding it WOT for about 5 minutes at a time. If it was going to starve for gas, it would have then.
« Reply #7 on: May 24, 2019, 02:19:07 PM »
reduced fuel flow lowers float bowl level which translates into a leaner air/fuel ratio. too lean and u will make a nice wrist pin viewing hole in the piston top.  this would happen before u noticed it starving for fuel. the oem in tank fuel filter is more than enough.
« Reply #8 on: May 24, 2019, 02:40:47 PM »
If you decide to rig for towing, you'll want to upgrade to the larger 1/4" orifice Dan-Marc.  I pulled a Timeout camper to Morgantown and had fuel starvation with the smaller DM.  With the larger one, doesn't happen.
