March 28, 2026, 05:39:10 PM *
Author Topic: Polyurethane Shock bushings part #  (Read 2434 times)
mauigts
Maui, HI
« on: May 25, 2019, 10:12:46 AM »
Having recently purchased another Valk. I am swapping out the shocks, for another pair of better looking (cosmetically) Honda Shocks. I want to replace the bushings on them before installing.
Does anyone have a part number, and or comparible source for a set of Polyurethane busings.?
Also, my (mainland Valk) has progressive shocks, and saw some urethane bushings for those on Ebay
https://www.ebay.com/itm/Progressive-Suspension-30-5010-Replacement-Shock-Bushings-Sleeves/141684105596?redirect=mobile
Anybody used these, do they fit on the Progressive Valk shock's. I should probably do both bikes.
« Last Edit: May 25, 2019, 10:47:34 AM by mauigts » Logged
« Reply #1 on: May 25, 2019, 10:32:36 AM »
VTX bushings that work with 1500 Valkyries: Honda 52489-HN0-671
Last much longer than OEM Valkyrie bushings.
mauigts
Maui, HI
« Reply #2 on: May 25, 2019, 10:50:30 AM »
Thanks, I just saw a utube video on the 1300 bushing change, and looked those up. I found them a tad expensive, I thought I saw a price of $18.01 ea. I COULD  have been mistaken, but really 18. Ea.
Thanks for that part number, yes these would be good. $2.95 ea. @ Bike Bandit, ...... unfortunately, they want to charge me $19.00 for shipping to put them in a plastic bag. Seems this is always my problem when living here in the islands, and trying to buy other than Ebay.
« Last Edit: May 25, 2019, 11:09:03 AM by mauigts » Logged
« Reply #3 on: May 25, 2019, 11:06:49 AM »
The part number listed by Gryphon Rider is about $2.50 at partzilla.
Progressive shocks come with metallic bushings, that doesn't mean
they never need changed, but yours are probably good, you might want
to look first...
mauigts
Maui, HI
« Reply #4 on: May 25, 2019, 11:17:39 AM »
Re: Progressive shocks. I lost a U joint while touring in Asheville, NC, and had to change it out, a d took a close look at them , From my memory, they have a metal sleeve surrounded by the donut bushing, and my upper looked like it could use a change.
 One of my problems, having a bike on the mainland to fly in and use, is that you have to have really good memory to recall all the nuances you notice, along with meticulous note taking,  (or both), as you don't get to walk around it, and do the little stuff. As when you do fly in, your pretty amped to just start loading gear, circling map routes, and trying to get yourself somewhere out on the open road, where they have some new micro beer, you've never tried.
« Last Edit: May 25, 2019, 11:41:59 AM by mauigts » Logged
« Reply #5 on: May 25, 2019, 12:57:44 PM »
Thread hijack.
My upper bushings are in 2 parts. Look like 2 squat dixie cups fitted bottom to bottom.
Unusual?
« Reply #6 on: May 25, 2019, 01:33:15 PM »
Thread hijack.
Unusual?
New OEM ones look like this:
« Reply #7 on: May 25, 2019, 01:49:31 PM »
Thread hijack.
Unusual?
Nuttin like mine.
« Reply #8 on: May 25, 2019, 02:47:03 PM »
https://www.rockymountainatvmc.com/   usually shipping $7.50 small orders
Vtx crowd are using nylon bushings. they get them cheap from mcmaster carr.
I found that a trailer spring uses same size, however they have to be cut in half to fit the shocks.
https://www.vtxcafe.com/showthread.php/61178-Shock-Bushing-Survey-Rubber-vs-Poly-vs-Nylon/page2
https://www.truckspring.com/trailer-parts/trailer-suspension/trailer-spring-bushings/PE-224.aspx
why nylon for shock eyelets or not?
https://grassrootsmotorsports.com/forum/grm/nylon-bushings/50124/page1/
mauigts
Maui, HI
« Reply #9 on: May 25, 2019, 06:49:25 PM »
I'LL KEEP LOOKING.  ROCKY MOUNTAIN DOESNT SHOW IN INVENTORY, EBAY, NON AVAILABLE, HONDA PARTSHOUSE, BIKE BANDIT, AND PARTSZILLA, ALL WANT ABOUT 5.00 PER BUSHING TO MAIL THEM TO ME.?
I am still riding, just have a nicer set of shocks sitting here and was going to swap them out.
« Reply #10 on: May 25, 2019, 06:58:52 PM »
redeye products are very good, better than oem.
https://redeye.ecrater.com/p/18385698/rear-shock-bushing-kit-ver-2
« Reply #11 on: May 26, 2019, 06:02:37 AM »
Thread hijack.
Unusual?
Nuttin like mine.
You have aftermarket 2 piece bushing
mauigts
Maui, HI
« Reply #12 on: May 26, 2019, 12:05:25 PM »
Thanks 98Valk. Redeye works, polyurethane bushings, 12.00/ 4.00 USPS shipping. Done !!!,
Appreciate it. One of the problems of living here ,, the shipping
« Reply #13 on: May 26, 2019, 12:58:21 PM »
welcome.
and u get four for that price and only the top ones take a beating and need replacement.
post your location under your handle.
« Reply #14 on: May 27, 2019, 07:01:24 AM »
Thanks. Just ordered to have in my parts stash.
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #15 on: May 27, 2019, 05:23:10 PM »
Was there someone that sold a "never have to replace" upper shock bushing?  I think it was a 2 PC set
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
« Reply #16 on: May 27, 2019, 05:30:18 PM »
Michael
one I saw was metal. from some research metal pounds the frame and shock bolt and is only recommended for race use and usually those parts need re-enforcement.
found this were nylon is not a good choice. high grade Polyurethane is the best choice.
"Polyurethane is an elastomer in the rubber family; it is not a plastic. We specifically exclude the use of plastics and nylons in all of our motor mounts and suspension bushings. Through our research and testing, we’ve come to the conclusion that plastic and nylon are not suitable for use in either of these locations, due to these materials’ lack of memory. By this, we mean that if plastic or nylon is compressed, it does not return to its original size; polyurethane does have this memory. Also, plastics and nylons have a shorter life expectancy than any urethane, especially the hardest compound polyurethanes."
https://www.akgmotorsport.com/materials-chart/
