December 31, 2025, 12:57:35 PM *
Author Topic: dead coil 1and 2 plugs  (Read 962 times)
slider
mulberry arkansas
« on: May 30, 2019, 10:38:57 AM »
where does power that feeds coils  hook up to coils from??Have a coil not getting power to either post..ground is good     coil is not firing.Does not appear to be getting power  on either terminal  on top of coil.
a proud navy veteran
jdp
« Reply #1 on: June 16, 2019, 05:54:37 PM »
Wish I could help you and I noticed a lot of people have read this but no one said anything, my best bet would be to buy a shop manual, I’ve fixed almost everything I needed to fix with it, good luck brother
« Reply #2 on: June 16, 2019, 08:50:21 PM »
PDF of service manual.
http://valkyrienorway.com/download.html
Easier to carry on trips. I use the paper one while working on the bike. PDF while searching on the computer to figure out how-to.
« Reply #3 on: June 17, 2019, 06:21:46 AM »
"Powering the coils" is an ECM function.
Bigwolf
Cookeville, TN
« Reply #4 on: June 17, 2019, 07:46:40 AM »
When the key is on, the black with white stripe wire should be showing 12 volts or more (depends on battery strength).  Neither terminal should show ground unless the engine is running!  The ignition module (ecm) provides the ground in accordance with proper timing.
