December 31, 2025, 10:53:09 AM *
Author Topic: Getting the splines to mesh - what are your hints? Help again!  (Read 3458 times)
mello dude
Dayton Ohio
« on: June 08, 2019, 02:48:31 PM »
Hi - working to get my rear wheel back on and struggling to get the splines to re-mess. Turning out to be a beach.... I made a couple spacers to try to use the axle bolt to pull it together, but dont like how it not working out.
Ok - what are your hints for messing the spines?
Please review last posts...  cooldude
thanks! Smiley
« Last Edit: August 10, 2019, 09:08:00 PM by mello dude » Logged
« Reply #1 on: June 08, 2019, 02:52:02 PM »
Lossen the four bolts on the diff and put tire on it will mesh. Tighten 4 bolts afternand all is good.  I
mello dude
Dayton Ohio
« Reply #2 on: June 08, 2019, 03:08:48 PM »
The four bolts on the pumpkin and houses the drive shaft?
Essentially the bolts that go over stud 37 in the partzilla fische..
https://www.partzilla.com/catalog/honda/motorcycle/1999/gl1500c-a-valkyrie/final-driven-gear
- I'll give it a shot..
« Last Edit: June 08, 2019, 03:14:26 PM by mello dude » Logged
« Reply #3 on: June 08, 2019, 03:26:29 PM »
Yes cooldude
« Reply #4 on: June 08, 2019, 03:36:44 PM »
If you put the trans in gear, the drive unit will lock. When you spin the wheel, you'll find the splines.
mello dude
Dayton Ohio
« Reply #5 on: June 08, 2019, 04:13:48 PM »
Yes cooldude
Quite a few cuss words going on, the nuts haven't been busted since the factory  Lips Sealed
mello dude
Dayton Ohio
« Reply #6 on: June 08, 2019, 05:33:29 PM »
Hey Bighead and Sandy --- did both of your hints - it worked! laugh Whoo hoo!
Been a moto geek wrenching foole for 30 years and learned something new.
Mucho Thanks!   cooldude
Valkpilot
What does the data say?
Corinth, Texas
« Reply #7 on: June 08, 2019, 05:59:01 PM »
The four drive-to-driveshaft bolts should only be tightened after the axle bolt is torqued.  If you didn't do it in that order, loosen and do it again.  (No need to disassemble.)
If you don't do it in this order, there's a possibility the drive and driven splines in the rear drive and star hub will not be well aligned and they will eventually chew each other up.
No matter what type of lube you use, no matter how much, the mis-alignment will win and ruin your drive.
« Last Edit: June 08, 2019, 06:01:35 PM by Valkpilot » Logged
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
mello dude
Dayton Ohio
« Reply #8 on: June 08, 2019, 06:13:23 PM »
Thanks for that tip - I havent torqued down anything yet.
I never would have thought of loosening the driveshaft bolts in the first place... Got to remember that! Smiley
« Reply #9 on: June 08, 2019, 06:29:45 PM »
There are some good "how to" articles in our shoptalk. You can pretty much read them all in one night. (Hope you regreased and put in new o-rings)
mello dude
Dayton Ohio
« Reply #10 on: June 08, 2019, 06:33:19 PM »
New o- rings and greased  cooldude
« Reply #11 on: June 08, 2019, 06:47:50 PM »
Just saw your other post. I forgot about all the chrome work you did. Looks excellent !  cooldude
« Reply #12 on: June 08, 2019, 07:33:34 PM »
Those are good hints and I use them along with another method. I slip the axle all the way through the wheel and into the left side of the swingarm, leaving out the spacer and brake mount at this time. That supports the wheel in line with the pumpkin and lets you use both hands to slide into place/mesh the splines. Once meshed, pull the axle out just even with the left side of the wheel so as to allow you to insert the spacer and brake mount. One more item....I never lift the rear of the bike more than 2-3 inches off the floor. Simply not necessary to R&R the rear wheel.
« Reply #13 on: June 09, 2019, 04:33:07 AM »
Yes cooldude
If those nuts never get loosened during a wheel change you are very lucky you dont have excessive wear on the splines.  Those nuts need to be loose when you torque the axle and then you immediately retighten those nuts.  The other thing is, why not remove the final drive and service the drive shaft.  It may be well overdue.
mello dude
Dayton Ohio
« Reply #14 on: June 09, 2019, 05:13:46 AM »
Yes cooldude
Thanks for the tip
« Last Edit: June 09, 2019, 05:34:08 AM by mello dude » Logged
mello dude
Dayton Ohio
« Reply #15 on: June 09, 2019, 05:40:55 AM »
Where are the shop talk articles located?
mello dude
Dayton Ohio
« Reply #16 on: June 09, 2019, 05:51:21 AM »
Thanks to everyone on here.  cooldude. I have wrenched on a lot of chain driven bikes, but not much on shaft bikes..
« Last Edit: June 10, 2019, 11:40:24 AM by mello dude » Logged
« Reply #17 on: June 09, 2019, 05:54:33 AM »
Thanks to everyone on here.  cooldude. I have wrenched on a lot of chain driven bikes, and not much on shaft bikes..
R/R of the drive and shaft is too easy to not do it while you have things apart
« Reply #18 on: June 09, 2019, 07:12:55 AM »
http://www.valkyrieriders.com/shoptalk/
Pluggy
NC
« Reply #19 on: June 09, 2019, 09:08:13 AM »
Yes.  This should have been put in the service manual.  The axle is used as an alignment tool.  Makes installing that wheel easy.
mello dude
Dayton Ohio
« Reply #20 on: June 09, 2019, 12:58:48 PM »
Wow! What a resource! I didnt know we had that. Waaay Cool  Cheesy Time for a bit of study.  Smiley
This turned out to be a great thread.  Cool
« Last Edit: June 09, 2019, 01:00:45 PM by mello dude » Logged
« Reply #21 on: June 09, 2019, 04:17:31 PM »
That was one method I figured out on my own a number of years back. An old military saying; "you want to find the easiest method of doing something, assign the task to the laziest guy in the outfit." I'm lazy!  Grin  I agree....it would have been nice if that method had been in the manual.  cooldude
mello dude
Dayton Ohio
« Reply #22 on: June 09, 2019, 05:48:02 PM »
ChrisJ CMA- just read your powerpoint on the rear wheel service. Great photos and instructions. Kudos to you sir. -- Looks like I missed the 3rd O-ring. - Ok, the rear is coming back apart. Diff and shaft too...
3rd O-ring looks like #34 on the fische?
Btw- how long is your red shock bar you made ? Great idea, I may as copy it.
Thanks again.  cooldude
« Last Edit: June 10, 2019, 11:37:04 AM by mello dude » Logged
« Reply #23 on: June 09, 2019, 07:04:38 PM »
Those parts fishes can be confusing at times. I’m not sure if that’s it or not. But here are some pretty clear pics of where the 3 o-rings are. Also, don’t forget the thrust washer.
http://www.valkyrieriders.com/shoptalk/Elusive%203rd%20O-Ring.htm
« Last Edit: June 09, 2019, 07:07:06 PM by meathead » Logged
mello dude
Dayton Ohio
« Reply #24 on: June 09, 2019, 09:05:59 PM »
From your pics, I have extras of the first 2 o-rings and thrust washer, but I'm unsure on trying to ID the 3rd one for replacement. The pic in the fische looks undersized.   Relatively simple to find when it's apart .
Update note -- the part number is listed in the 3rd ring article -- DUH! lol  Roll Eyes
« Last Edit: June 10, 2019, 11:44:42 AM by mello dude » Logged
« Reply #25 on: June 10, 2019, 05:56:59 AM »
@John - just read your powerpoint on the rear wheel service. Great photos and instructions. Kudos to you sir. -- Looks like I missed the 3rd O-ring. - Ok, the rear is coming back apart. Diff and shaft too...
I’ll measure it tonight. I believe its 10” hole center to center
« Last Edit: June 10, 2019, 06:28:10 AM by Chrisj CMA » Logged
« Reply #26 on: June 10, 2019, 11:20:38 AM »
The one in the slide show is 9.75 center to center. I have since made a longer one that works better with stock pipes it’s an inch longer. The 10” would be all you need
mello dude
Dayton Ohio
« Reply #27 on: June 10, 2019, 11:38:43 AM »
Thanks Chris
Thank you!  cooldude
Um, Sry I was mixing you up with John...  Smiley
« Last Edit: June 10, 2019, 11:46:26 AM by mello dude » Logged
« Reply #28 on: June 10, 2019, 11:53:08 AM »
Thanks Chris
Thank you!  cooldude
Tis ok. Glad it’s still helpful
mello dude
Dayton Ohio
« Reply #29 on: June 15, 2019, 05:10:58 PM »
Ok - Did it...Had 2 of the 4 studs come loose instead of the bolts. Got new studs on the way to fix. Yay Partzilla..
But what now? (yeah I am a relative rookie on drives for shaft bikes) -
- I have pulled on the drive shaft and it doesnt want much to come loose. I looked in the FSM  for hints. Also, reinstalling the driveshaft into the U joint doesnt look like much fun to get it alined and pushed together home. .. The bike only has 20K miles on it so I really dont want to teardown any farther...
 --What more hints do you have..... Many thanks in advance.
« Last Edit: June 15, 2019, 07:41:22 PM by mello dude » Logged
« Reply #30 on: June 16, 2019, 05:30:36 AM »
Give it a quick, sharp tug while holding the shaft upright. Have something soft underneath the pumpkin to cushion it's fall. There is a snap ring on the end that is impeding its removal, but a sharp tug will do it.
mellowyellow#7933
Verner, Ontario, Canada
« Reply #31 on: June 16, 2019, 05:52:14 AM »
To re-install driveshaft to u-joint lift swing arm to horizontal or slightly above. May have to rotate shaft a little to align splines but should slide right in.
sixlow
St. Augustine, Fl.
« Reply #32 on: June 16, 2019, 05:59:16 AM »
Big BF video
http://youtu.be/Y6QUcCxOcPE
Rosie
Clintonville WI 54929
« Reply #33 on: June 16, 2019, 08:33:10 AM »
As Mello Yellow said, when you go to put it back together LIFT the swing arm and it will go together easy.
1999 Valkyrie tourer
2003 Valkyrie standard
mello dude
Dayton Ohio
« Reply #34 on: June 16, 2019, 12:29:34 PM »
Videos by the mime mechanic... lol.  Grin  great job! and thanks! ...... you should do more.  cooldude
« Last Edit: June 16, 2019, 12:37:00 PM by mello dude » Logged
mello dude
Dayton Ohio
« Reply #35 on: June 16, 2019, 12:32:42 PM »
Thanks for the tip... for some reason, it reminded me of shooting a foul shot at basketball. It might go in or it might not.  - I'm waiting for some parts to arrive, so we'll see how it goes...
« Last Edit: June 16, 2019, 12:35:35 PM by mello dude » Logged
« Reply #36 on: June 16, 2019, 01:56:50 PM »
What works for me is to sit directly behind the opening of the swing arm that the shaft goes in. You have a better sense of aim. Then if it doesn’t go right in shake the final drive left right and up and down a little more violently that you might think while applying firm consistent pressure on the back of the final drive.  It will go in quick that way.
mello dude
Dayton Ohio
« Reply #37 on: June 22, 2019, 09:06:39 AM »
Got everything regreased, molyed, re - oringed and ready to go..
But ever struggling to get the drive shaft into the U joint.... AAAAAWWWWW!
Lots of fine words said...
Ok more hints please.  Shocked
Bone
« Reply #38 on: June 22, 2019, 09:11:06 AM »
With a light look into the tube and see how the end of the u joint is laying you might need to alter your attack.
mello dude
Dayton Ohio
« Reply #39 on: June 22, 2019, 09:41:30 AM »
Agreed --- a step back and thinking wtf is going on.... .I added a scissor  jack to help balance the drive assembly.... before I was trying to balance on my knees...
Then shaking the sh!t out of it....
Pure stubborness wins! -- Got it! Whew!  A long 2 hours...
« Last Edit: June 22, 2019, 09:44:52 AM by mello dude » Logged
