December 31, 2025, 12:57:34 PM *
Author Topic: Flo Pro baffle packs for exhaust  (Read 1278 times)
Davemn
Minnetrista, Minnesota
« on: June 13, 2019, 12:52:06 PM »
Has anyone ever tried these? Trying to get rid of my awful drone and quiet things down a bit.
« Reply #1 on: June 13, 2019, 03:50:02 PM »
If it’s stock. All you need is piggie extensions
Eliminates drone and makes it quite for the rider
« Last Edit: June 13, 2019, 04:04:19 PM by Chrisj CMA » Logged
Davemn
« Reply #2 on: June 13, 2019, 05:11:05 PM »
Nope I’m beyond that.....glasspacks. Thanks though!
Ken aka Oil Burner
Mendon, MA
« Reply #3 on: June 13, 2019, 06:54:00 PM »
If you've got room behind the glasspacks, you could try something like these: https://www.hardin-marine.com/p-12622-4-slip-in-silencer.aspx    I haven't found a decent video showing them in actual use, but they supposedly fit in 4" pipes (which I'm assuming you have if you did the glasspack conversion).
Steve K (IA)
Cedar Rapids, Iowa
« Reply #4 on: June 17, 2019, 07:07:44 PM »
Contact Mark T.
States I Have Ridden In
Fazer
« Reply #5 on: June 18, 2019, 04:34:33 AM »
I put the slip in silencers in my truck stack, then added Grumpy's tips for a little more length (and the bling).  Still too loud for me, so I swapped with my son when he bought his 2000 Tourer.  I am now very happy with stock pipes, and he likes the louder modified truck stacks. Grin
Nothing in moderation...
« Reply #6 on: June 18, 2019, 02:44:22 PM »
From my web site.  These cut the volume down to less than half of what it is w/o.  Preserves the timbre and the power - no difference on the dyno with them in or out as each pulse goes thru all 3 chambers.  They are adapted from the original back baffle section of the OEM exhaust.  So they are used, some very lightly.  Usually I recess them about 4" so they are not very visible. They can be made even quieter by stuffing a wad of SS wool between the glasspack and the silencer.  Held in place with one screw in the stack - I put it on the tire side.  I charge $60 for the labor on the lathe to fit them to the stacks, n/c to replace the baffles if they were drilled; the cores cost money so I pass it on - $90.  $130 for silencers (+ cores) to fit 5" stacks as they get CNC cut bulkheads to fit to the bigger stacks.  If you supply the cores it's $60 (4" stacks) + shipping, no core charge.
The exhaust page link describing these is at http://www.horseapple.com/Valkyrie/Valk_Products/M2W_Exhaust__System/m2w_exhaust__system.html
« Last Edit: June 18, 2019, 02:50:31 PM by MarkT » Logged
