December 31, 2025, 12:57:34 PM
Turn signal indicator
Topic: Turn signal indicator (Read 952 times)
Rosie
Clintonville WI 54929
June 16, 2019, 08:54:50 AM »
I would like to replace turn signal indicator bulb in headlight bucket with a bright LED so I remember to shut it off. Is it a 194 bulb? Has anyone done this? And what color bulb did you use? Couple years ago i replaced dash bulbs with led and that was a nice improvement. 99 tourer. Thanks.
1999 Valkyrie tourer
2003 Valkyrie standard
Re: Turn signal indicator
June 16, 2019, 09:30:32 AM »
I just hardwired in a red LED to each side of the turn signal circuits then to ground to fix the problem of inadvertent 4-ways after changing the bulbs in the turn signals to LED. So I have 2 LED's stuffed in the indicator socket. Don't recall if I added a resistor to ea LED. Likely not as there is already a resistor in ea circuit with the LED arrays to prevent too much power blowing out the LED's in the indicator. They are bright ones I use to make my Highlighters. Very obvious much brighter than the 194 OEM incandescents. I don't recall where I bought them it was some time ago but here's a source.
https://www.radioshack.com/collections/leds-and-holders/products/4-7mm-round-red-led?variant=19425623900230
Pretty easy project actually, an hour or so with a soldering iron and some shrink wrap.
Last Edit: June 16, 2019, 10:22:18 AM by MarkT
June 16, 2019, 09:33:38 AM »
I think you have to add some diodes also. I just added a little buzzer to my Standard. I can't hear it at 60, but it reminds me to turn them off 99% of the time.
June 16, 2019, 09:36:02 AM »
Quote from: meathead on June 16, 2019, 09:33:38 AM
An LED is a diode.
Wayn-O
Orem, UT
June 17, 2019, 08:48:47 AM »
People say that these work with no modification, even in the turn signals. Haven't done it myself, but I saw it on a thread on the Honda Valkyrie Facebook group.
https://www.amazon.com/dp/B072MYWN7N/ref=cm_sw_r_cp_apa_6EzUBbNNWS9B2?fbclid=IwAR2QVdCZl_k-MNhFYVWYw4r1nHZO5LZpRWB2VXF0TIbA9JEeJWkANrTILmk
2000 GL1500C Valkyrie
2003 VT1100C Shadow Spirit
1998 VT1100C Shadow Spirit
1983 VF750C V45 Magna
=> InZane XXV
