November 20, 2025, 03:13:39 PM
Got everything I need?
Topic: Got everything I need? (Read 2433 times)
BamaDrifter64
Athens, Alabama
November 28, 2009, 06:12:57 AM »
I'm getting ready to change my rear tire/service the rear end by myself for the first time and want to make sure I have everything I need. I have the tire, tire o-rings, valve stems, dynabeads, grease and gear oil. The manual also says I need to get a stopper ring and a seal for the drive shaft. Am I missing anything?
Dave
http://vrcc.photostash.com/vrcc_24883/photo(1).JPG
http://vrcc.photostash.com/vrcc_24883/photo.JPG
Misfit
Colorado Springs Colorado
Re: Got everything I need?
November 28, 2009, 07:51:28 AM »
You mat also want to replace the thrust washer in the final drive and the crush washer under your drain plug.
BamaDrifter64
Athens, Alabama
November 28, 2009, 08:14:06 AM »
What is the thrust washer? I'm looking at the manual and I don't see anything listed as a "thrust washer" in the instructions or the drawings.
Dave
Bone
November 28, 2009, 08:24:57 AM »
It is under the final driven flange. Very thin and maybe stuck to the flange in the grease. I wipe mine clean and reuse because I never remember to order one.
Look at the parts at HDL they are about $4.00.
Bone
November 28, 2009, 08:28:22 AM »
Here is a link for HDL
http://www.hdlparts.com/fiche_section_detail.asp?section=148814&category=MOTORCYCLES&make=HONDA&year=1998&fveh=3477
Dave Weaver
Seymour, IN
November 29, 2009, 12:40:51 PM »
Dave,
You may want to have a set of dampers on hand in case yours are getting sloppy, and rear brake pads are easier to change when the rear wheel is off. Also, a lot of us keep rear wheel bearings on hand in case the ones in the bike are needing replaced. The thrust washer is part #42616-MAJ-G20. The thrust washer is plastic, but you may be able to reuse yours if not chewed up too bad. Good luck, and take care of that blue bike of mine.
Do unto others as you would have them do unto you.
BamaDrifter64
Athens, Alabama
Reply #6 on:
November 30, 2009, 01:24:29 PM »
Thanks, Dave, I'll be sure to pick all that up....I want to take real good care of your bike while I have it....
Dave
Ron K
Trinity Alabama
Reply #7 on:
December 04, 2009, 07:56:06 PM »
Dave, If you need any help feel free to give me a call.
Ron
BamaDrifter64
Athens, Alabama
Reply #8 on:
December 05, 2009, 07:03:49 AM »
Thanks, Ron....right now the only problem I have is finding time to get the materials....and then finding time to change out the freakin' thing!!!
Dave
=> InZane XXV
