December 31, 2025, 11:01:57 AM *
Author Topic: thoese liiiiitle tiny screws that hold the IS fairing speaker covers  (Read 1274 times)
NighthawkVTX
Gainesville, Fl
« on: June 30, 2019, 09:40:16 AM »
does any one know if those screws are special honda parts or are they a common screw?
If at first you don't succeed, then perhaps skydiving isn't for you
« Reply #1 on: June 30, 2019, 11:15:14 AM »
Common metric
Steve K (IA)
Cedar Rapids, Iowa
« Reply #2 on: June 30, 2019, 11:50:14 AM »
The thread might be common, but...No!  They are not a common screw.  They are a "shoulder" screw and you won't find them at the hardware store.
Go ahead and get something from the hardware store and you WILL split the plastic on those panels. That's why they are a shoulder screw...keeps from tightening on the plastic instead of against the nut/insert.
    SCREW, SPECIAL (5MM)
90107-MBY-000                       $2.09  at Partzilla
« Last Edit: June 30, 2019, 11:57:38 AM by Steve K (IA) » Logged
States I Have Ridden In
« Reply #3 on: June 30, 2019, 01:50:55 PM »
Actually, the shoulder is a washer.
This is one I took a picture of during my recent build project.
« Reply #4 on: June 30, 2019, 02:12:01 PM »
I prefer an allen head and, yes, you can get them at almost any hardware store.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #5 on: June 30, 2019, 02:16:31 PM »
Wrong screw.  I think...because I no longer have them on my fairing, what you are showing is a screw that holds the air deflectors that are on the underside edge of the fairing.  (Edit) Just checked a parts fiche.  What you are showing Is for those air deflectors.  And that screw should be a shoulder screw also but different, larger head.
SCREW, SPECIAL (5X17) 90105-MBY-000
RUBBER, PROTECTOR GASKET 18293-GN2-000
The screws that hold the speaker panels and gauges panel Are shoulder screws.
« Reply #6 on: June 30, 2019, 03:31:21 PM »
+1, stainless steel Allen head was my choice  cooldude
NighthawkVTX
Gainesville, Fl
« Reply #7 on: June 30, 2019, 04:04:50 PM »
One thing for sure, the head strips out really easy when they dont want to come out. One is  stuck
« Reply #8 on: June 30, 2019, 05:17:33 PM »
              What Willow said AND it be a done deal on Phatt Ghurl!  cooldude RIDE SAFE.
ridingron
Orlando
« Reply #9 on: June 30, 2019, 08:36:49 PM »
$1.81 @ https://www.partsfish.com/oemparts/a/hon/506c2f75f870023420a31b6c/fairing
« Reply #10 on: July 01, 2019, 09:37:26 AM »
If it's the wrong screw for those panels, then someone in the past removed and replaced it from the air deflectors. I'll look them over the next time I take the inside fairings off.
As for a screw with a shoulder, I was going to use a rubber o-ring. Allows for a shoulder and gives a little compression to act like a washer. Just tighten till it touches, no more.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #11 on: July 01, 2019, 04:55:23 PM »
I've read in the past where guys put a little o-ring on a screw for the speaker panels.  If it stays tight and works, then ...  Wink
Paladin528
« Reply #12 on: July 16, 2019, 09:29:20 AM »
if it strips then you are not using a JIS screwdriver to remove it.
These are NOT Phillips screws they are Japanese Industrial Standard Screws.
Special tip fits better than a phillips
