December 31, 2025, 11:07:18 AM *
Author Topic: Tranny Output Shaft  (Read 1001 times)
Dragon4056
Waco, TX
« on: July 01, 2019, 07:27:35 AM »
Hey Folks, 2001, 26k miles. Always lubed the wheel and pumpkin splines at tire change. PO advised he never had the final drive off. I will remove and check the cup and driveshaft. No telling what I will find, although runs real smooth. My question is while apart should I go ahead and remove the swing arm and  u-joint and grease the tranny output shaft and check the u-joint? 26k miles isn't many just didn't know if the output shaft is a problem area like the rest of this driveline. And I've heard so many opinions on the use of Molly in the cup and driveshaft splines, is it necessary? Or will a good Marine waterproof grease suffice? Maintenance will always be done around 10k miles. Not trying to open up a can of worms here, knowing this is a sensitive topic. LOL
« Reply #1 on: July 01, 2019, 07:31:31 AM »
u don't need to remove the swing arm. the shaft slides out and just remove the u-joint then after pulling the cover back.
Dragon4056
Waco, TX
« Reply #2 on: July 01, 2019, 07:36:25 AM »
So, sounds like enough room to slide the u-joint to the rear and remove out of the boot space?
Dragon4056
Waco, TX
« Reply #3 on: July 01, 2019, 07:38:30 AM »
And CA, whats your opinion on the use of the Molly?
« Reply #4 on: July 01, 2019, 07:53:08 AM »
yes
can download manual for free here
http://www.valkyrienorway.com/download.html
« Reply #5 on: July 01, 2019, 08:13:27 AM »
I'm a proponent of moly paste and grease per the manual.
drive shaft/U-joint gets the grease and I mix the paste and grease together for the splines in a 2:1 ratio.
https://www.tsmoly.com/grease-moly-grease-p-251.html
https://www.tsmoly.com/anti-seize-lubricants-compounds-moly-paste-with-mossub2sub-p-93.html
make sure the three final drive O-rings are replaced, some do it every tire change, I've done it every other.
last change I used the red-eye upgraded o-rings. should be good for four tire changes.
https://redeye.ecrater.com/p/18218041/final-drive-o-rings-for-valkyrie-polyurethane
« Reply #6 on: July 01, 2019, 08:48:13 AM »
https://www.facebook.com/BigBF5/videos/576331115809274/
« Reply #7 on: July 01, 2019, 09:50:57 AM »
At 26K you don't need to remove the U joint but it can't hurt. The drive shaft splines from the joint back to the input cup takes moly GREASE. Honda defines this as 2-3% moly. Valkvoline Durablend is 3% moly already. No need to mix. A member (RATDOG) in Seattle use to make a schmooie of Moly paste and Bel Ray waterproof grease. That worked for him. I used Bel Ray as is with no issues on the wheel splines. My last Valk I sold had 155K with the original splines with no wear.
