December 31, 2025, 11:06:51 AM
Dan Marc questions
Topic: Dan Marc questions (Read 851 times)
HBFL
Dan Marc questions
July 08, 2019, 01:40:57 PM »
The DM .250 is on its way.
Is 5/16 ID fuel line ok on the petcock line and the two carb feed lines?
The carb lines measure out around 3/8 ID.
Thanks in advance!
Re: Dan Marc questions
July 08, 2019, 02:08:53 PM »
That's what I used.
along with a brass T coming off the Dan Marc.
Leathel
New Zealand
July 08, 2019, 02:59:34 PM »
I went T on the AFC valve to the carbs and 3/8 hose to the tank which is a loose fit on the pingel, I use a hose clamp that is easy to access with a long screw driver, makes it easy to get the hose on the tank
=> InZane XXV
