December 31, 2025, 11:01:57 AM *
Author Topic: U-Joint  (Read 1051 times)
dancnman
Houston, Texas
« on: July 10, 2019, 06:03:50 PM »
Can't tell you how bad i feel having to ask this, but here goes: Which way does the u-joint go? Long part to the engine or the rear?
Reality is that thing which does not change simply because I choose to ignore it.
« Reply #1 on: July 10, 2019, 06:27:26 PM »
It will only work one way. The splines are different diameter. Prove it to yourself  by sticking the driveshaft splines in each end. It will only fit correctly at one end. Then you will know which way it goes
dancnman
Houston, Texas
« Reply #2 on: July 11, 2019, 03:27:09 AM »
Well, that I didn't know. Thanks.
Bigwolf
Cookeville, TN
« Reply #3 on: July 11, 2019, 04:32:04 AM »
Long end toward the engine
Grandpot
Fort Mill, South Carolina
« Reply #4 on: July 12, 2019, 09:59:33 AM »
All good advice above.  If I remember correctly,  when you look at the U joint in the parts fiche, it is deceiving.  The picture looks like the short end is forward,  but actually it is the long end.
