December 31, 2025, 11:07:32 AM *
Author Topic: Wiring help: Tourer Fender on Interstate  (Read 1130 times)
Savage
United States
« on: July 16, 2019, 07:50:47 AM »
 I removed the trunk from an interstate and do not plan on putting it back on.
I have installed a taillight/brake light from a Tourer, along with the fender wiring loom from a Tourer.
Can somebody help me out on matching up the wiring here?
I am not the best with electrical. I have the diagrams in front of me and I see where things go on the Tourer vs Standard... what I cannot determine is what wires need to be connected to each other to make everything work. For instance right now I have a working taillight/brake light, working turn signals, but the constant-on feature of the turn signal lights is not working. I put in brand new dual-filament bulbs and swapped out the turn signal relay just to be sure. No dice.
I have been searching the tech forum and I KNOW others have dealt with this during Supervalk conversions. So i apologize for my inability to find whatever writeup might exist.
Columbia, South Carolina
Bagger John - #3785
« Reply #1 on: July 16, 2019, 08:03:41 AM »
The stock rear turn signals are single-filament bulbs (1156). They were never intended to function as running lights.
Many of us have swapped the rears for fronts (which use an 1157 dual-filament bulb). This leaves us with two problems: Making them function as running light AND turn signals, and the fact that a constantly illuminated yellow light at the rear of a motor vehicle will often get you a ticket.
I made "Y" adapters and ran the running-light connections from the front signals to the back of the bike, where they tie into the running light connections of the new signals. Another way is with a Badlands or similar run-turn-stop module (which is how my current I/S is set up). This approach doesn't require modification to the existing signal arrangement; it's all done via the controller and one wire per signal.
Lenses...easiest thing to do here is to swap them for a pair of Kuryakyn deep-dish bezels w/ red lenses, or use the same setup w/ clear lenses and red bulbs. I've also converted the lenses from Blazer C827R marker lights to function as rear lenses on the 2000-up (single screw) signal assemblies.
I'm sure others will chime in with their thoughts.
« Last Edit: July 16, 2019, 08:14:01 AM by Bagger John - #3785 » Logged
Paladin528
« Reply #2 on: July 16, 2019, 08:54:16 AM »
I did the same thing.  I had to buy a Tourer harness because the connectors are different from the interstate to the tourer due to the lights.
I cannot remember which one I needed to complete the install but I believe it was number 8 in this diagram.
https://www.partzilla.com/catalog/honda/motorcycle/1999/gl1500ct-a-valkyrie-tourer/wire-harness
« Reply #3 on: July 16, 2019, 04:55:56 PM »
No. 8 is the tilt sensor.
snip
I never thought of that, I've only been wanting to add a brake light to my IS, not Supervalk and change my turn signals into running lights. But if I change the rear wires to a Std/Tourer wire harness, then I have one loose wire. Wont matter since I'm keeping my trunk, but it might be nice to swap out, and have extra running lights.
« Reply #4 on: July 16, 2019, 05:41:14 PM »
snip
Gordon I just spliced my taillight to the existing wites on my IS and also put a spoiler on the trunk with an LED brake light. Very simple.
Paladin528
« Reply #5 on: July 17, 2019, 07:39:31 AM »
snip
Sorry typo.... Number 6 is the harness
