Disco
Republic of Texas
« on: November 30, 2009, 10:27:33 AM » |
Can anyone tell me the inside diameter of the oem fuel line? TIA, DFG
2000 Bumblebee "Tourer", 98 Yellow & Cream Tourer, 97 Rescue blower bike 22 CRF450RL, 19 BMW R1250RT 78 CB550K 71 Suzuki MT50 Trailhopper .jpg) VRCC 27,916 IBA 44,783
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: November 30, 2009, 11:05:22 AM » |
I believe it's 7mm but 5/16ths works. The only stock fuel lines on my Valk are the ones running from the T to the carb banks.
Marty
Bone
« Reply #2 on: November 30, 2009, 11:14:45 AM » |
My notes say it's 8mm or 3/8. Pingle uses 5/16.
Now I wonder which is correct ?
X Ring
« Reply #3 on: November 30, 2009, 11:49:06 AM » |
8mm is between 5/16ths (20/64ths) and 21/64ths whereas 10mm is 13/32nds, 1/32 bigger than 3/8ths.
Disco
Republic of Texas
« Reply #4 on: November 30, 2009, 02:58:36 PM » |
Thanks everybody. I found another hint in the form of the Purolator F10024 inline fuel filter that I've read is one commonly used. Its inlet/outlet is .31 inches. 5/16ths = .3125 http://www.purolatorautofilters.net/resources/Popup/Pages/PartDetailPopup.aspx?partnum=F10024
X Ring
« Reply #5 on: November 30, 2009, 04:31:41 PM » |
You're not by chance running a belly tank are you?
Crazyhorse
« Reply #6 on: November 30, 2009, 04:49:24 PM » |
The fuel petcock nipple measured 3/8 ".
« Reply #7 on: November 30, 2009, 04:51:42 PM » |
Say what? ???
« Reply #9 on: December 01, 2009, 06:44:41 AM » |
I believe the original fuel line is 8mm.. So when installing an in-line filter I just force fit a 3/8" unit..
Disco
Republic of Texas
« Reply #10 on: December 01, 2009, 07:21:59 AM » |
You're not by chance running a belly tank are you? No belly tank.
X Ring
« Reply #11 on: December 01, 2009, 09:35:25 AM » |
I've found a 5/16ths is a tight fit also. The stock fuel lines have thinner walls than the ones you get at the parts store. Marty
Disco
Republic of Texas
« Reply #12 on: December 01, 2009, 01:52:18 PM » |
And here's another reason we prefer to do our own work... I called the service dept at the dealership where I trade and they told me 1/4".
