March 28, 2026, 08:21:43 AM *
Author Topic: Highway pegs on Interstate  (Read 586 times)
Big Rick
2000 Valkyrie Interstate
Franklin....Ohio
« on: July 22, 2019, 02:08:40 PM »
I was wondering what size clamp you need to fit the curved part of the Interstates crash bars ?
 I have pegs on the lower part under the engine, but I keep burning the inside of my calves crazy2
       Big Rick
« Reply #1 on: July 22, 2019, 02:38:45 PM »
1 and 1/8 inch.
Watch out, many kits come with HD 1 1/4" clamps included.
0leman
Klamath Falls, Or
« Reply #2 on: July 23, 2019, 05:55:17 AM »
What Jess said.
I have my Hwy pegs mounted on the curve without problems.
« Reply #3 on: July 23, 2019, 06:10:03 AM »
Yeah, with short legs, I have often burned my calves on the rear valve cover corners.   And with heavy jeans, the burn sort of creeps up on you.
You either have to slide your feet wider, more to the outside of the Hwy pegs, or adjust the pegs so your knees are a bit more bent.  This means angling the pegs more to the rear.  They look crooked mounted that way when folded up or deployed.  They look right mounted a straight 90 degrees out, but they don't work right that way.  Our legs go this way V, not this way H.
If they are on offsets, roll the offset back a tad for a bit more bent knee to avoid the burn.
Now, it's when I put my boot heels over the pegs and lock my knees out, I get the burn.
« Last Edit: July 23, 2019, 06:32:15 AM by Jess from VA » Logged
0leman
Klamath Falls, Or
« Reply #4 on: July 24, 2019, 05:29:30 AM »
For us with a bit longer legs, one can do as Jess does and rest your heels on the pegs without touching any of the hot spots.    2funny
Only problem with having my pegs on the curve is during the colder months feet get colder quicker.
« Reply #5 on: July 24, 2019, 06:11:52 AM »
        My I/S came with the hwy pegs mounted to the curve of the ahem crash bar. Took some adjustment to find MY sweet spot but it are doable. I'm 6' 2" tall and now able to git comfortable with the pegs on long or short rides. I believe they are Kurys. Had they Not been on My I/S when I bought it i Would have purchased these without question. RIDE SAFE.
« Reply #6 on: July 24, 2019, 07:59:54 AM »
This particular style Kuryakyn highway peg L-arm is versatile for precise placement/adjustment. Don't recall the number but look for the shape.  Tried others; this one works well.
Big Rick
Franklin....Ohio
« Reply #7 on: July 24, 2019, 01:03:02 PM »
Thank you guys for all the replies , I am going to fiddle around with them some more to see what I need to do
   Big Rick
shortleg
maryland
« Reply #8 on: July 25, 2019, 05:42:20 AM »
I think it was Revco that sold mountings just for the IS that worked well
Because they were designed fro the the scoops etc.
« Reply #9 on: July 25, 2019, 05:44:56 AM »
            The lower peg on MarkT bike is ZACKLY what I have on Phatt Ghurl.  cooldude RIDE SAFE.
