December 31, 2025, 10:55:20 AM *
Author Topic: 1500 Brake Light  (Read 1186 times)
markymark640
Augusta Georgia
« on: July 29, 2019, 03:22:51 PM »
I know a lot of IS owners like adding the standard tail light to their bikes so there is better visibility on the back side.
There's one listed on ebay now.
https://www.ebay.com/itm/1998-Honda-Valkyrie-1500-Gl1500ct-Tour-Taillight-Rear-Tail-Brake-Light/173980851642?epid=1811824642&hash=item2882111dba:g:8DEAAOSwlWBdP2uR:sc:USPSPriority!30815!US!-1
I'm not selling it, I just happen to see it and thought someone might be interested
Bagger John - #3785
« Reply #1 on: July 30, 2019, 08:40:45 AM »
Make sure you check clearance of the front trunk stay crossmember to the taillight housing prior to buttoning everything up. Every one of mine (that I've added a light to or a trunk to) required a bit of material to be removed from the two vertical channels which position the rear I/S seat tab...lest they impinge on the housing and damage it.
« Reply #2 on: July 30, 2019, 09:25:34 AM »
My IS didn't have any clearance issue with the trunk mounts. (and I used all OE parts)
I read the clearance issue was a factory CB under there.
« Last Edit: July 30, 2019, 10:10:51 AM by Jess from VA » Logged
SCain
Rio Rancho, NM
« Reply #3 on: July 30, 2019, 09:37:19 AM »
I believe BigBF addressed this years ago on his website, he had instructions on how much to trim off of the seat bracket to clear the light housing.
The CB also interfered with the light housing, I know you could modify the mounting brackets so they could work together.
http://bigbf.com/bigbf_shop/mod_i-s_trunk/pages/P0006623.htm
« Last Edit: July 30, 2019, 09:40:16 AM by SCain » Logged
Steve
Ken aka Oil Burner
Mendon, MA
« Reply #4 on: July 30, 2019, 10:25:25 AM »
Well, somebody already got to it. Sold.
« Reply #5 on: July 30, 2019, 08:10:15 PM »
I've the CB bracket for under the trunk. But I've the Yamaha CB. I just bought the Yamaha mount (box), and their longer cables, so I can reach the side cover.
When I get too it, I'll be adding it to my Project post.
http://www.valkyrieforum.com/bbs/index.php/topic,96578.0.html
Bagger John - #3785
« Reply #6 on: July 31, 2019, 05:28:02 AM »
I opened up the tool tray area of the battery box and installed my first I/S's CB in there. A pair of closed-cell foam wedges were fabricated so as to hold the setup in position.
My current I/S will have this done when I install its radio. My Tourer has the Hondaline accessory CB radio set atop the battery box cover, and I'm going to move its Yaesu dual-band ham radio chassis (currently mounted under the trunk stays) into the toolbox area. Depending on fit, I may set the CB in the toolbox compartment and put the FTM-10SR chassis on top of the battery box cover.
« Reply #7 on: August 05, 2019, 03:15:52 PM »
Yup!  Roll Eyes
