December 31, 2025, 10:55:14 AM
Does my Rear need more maintenance?
Topic: Does my Rear need more maintenance? (Read 1263 times)
Davemn
Minnetrista, Minnesota
August 05, 2019, 05:21:28 PM »
Ok some dumb questions. 50,000 miles on my Standard. I have put on at east 4-5 tires since buying my 98. I have a good handle on greasing the parts attached to the wheel/hub itself. I have replaced the bearings and also the o-rings. Changed gear oil frequently. Everything looks really good in there....no issues. However, I have never inspected anything forward of the “pumpkin “. Am I missing something? Should I tear into it? I know there are gears and a U-joint forward. Also a rubber boot that’s a real bearcat I've heard. I will add that I don’t drive it much anymore....maybe 1,000 miles a year.
Thanks in advance.
Re: Does my Rear need more maintenance?
August 05, 2019, 05:25:31 PM »
I wouldn't worry about it. You could go another 50k or more on that ujoint. I would clean and grease the pinion cup if you have not done that.
August 05, 2019, 05:32:05 PM »
Here's a how-to from ChrisJ, found in shoptalk.
http://www.valkyrieriders.com/shoptalk/rear_end_service.pptx
Bigwolf
Cookeville, TN
August 05, 2019, 05:37:13 PM »
If you have put 20,000 or more miles on it since the drive shaft, pinion cup and U-joint were inspected, I would pull that all out and inspect it. If it is all in good shape, I would then re lubricate and reassemble with a new seal. I like to replace that seal every 20K or so just because it is so cheap and yet, if it fails, the resulting damage is currently about $120 USD.
August 06, 2019, 07:49:31 AM »
I hope you can see this.
https://www.facebook.com/BigBF5/videos/576331115809274/
mello dude
Dayton Ohio
August 08, 2019, 06:05:28 PM »
Does my rear end need more maintenance?
https://www.youtube.com/watch?v=KV6UhEpxUVk
Reply #6 on:
August 09, 2019, 06:57:36 AM »
The start of your quest for answers:
Answers may be here
=> InZane XXV
