December 31, 2025, 09:10:14 AM *
Author Topic: JIS screwdriver update info  (Read 3023 times)
« on: August 20, 2019, 09:07:57 AM »
most phillips screwdrivers today work on JIS screws due to a new standard as stated below. I have some recently purchased harbor freights  https://www.harborfreight.com/2-x-4-inch-phillips-screwdriver-94707.html
and a few yrs old craftsman and they work great on JIS screws. The craftsman still had a point which I flattened which made it to work even better. The new standard already has the flat tip.
"The reason these companies have changed to DIN 5260/ISO 8764-1 is because the new standard is designed to work in both Phillips and JIS screws. For the most part that is true, it does work on both screw types, but like anything meant to work with multiple things, the middle ground means compromise. The JIS standard screwdriver will always outperform a DIN/ISO screw driver in the worst of conditions on a JIS screw, and the same is true in reverse."
http://rtstools.com/jis-vs-phillips-screwdrivers-and-where-to-buy-a-jis-screwdriver/
« Reply #1 on: August 20, 2019, 09:18:47 AM »
Figures, I just today finally got around to adding a good JIS screwdriver to an Amazon order.
Who else goes on Amazon for 2-3 best-buy things they need, then wanders around the house looking for small things that should have been fixed years ago, and running back to the puter and adding them to the order?  Ergo, the JIS, and a couple minimalist Sticky holsters.
« Last Edit: August 20, 2019, 09:22:00 AM by Jess from VA » Logged
« Reply #2 on: August 20, 2019, 09:24:16 AM »
My tactics are this: Use Philip screwdrivers that are in very good condition. Place in Japanese screw. Tap a few times with hammer.  BOOM magic. Japan screw changes to Philips screw from then on. That’s my story and I’m sticking to it
« Reply #3 on: August 20, 2019, 09:32:12 AM »
from the same web site.
"Most JIS advertised screwdrivers sold today by companies like Vessel, Hozan, and others are actually conforming to a new standard: DIN 5260 which is identical (at the tip) to the newer ISO 8764-1."
"To date, I have only been able to find one confirmed manufacturer that still uses and builds to JIS B 4633, and that is SUNFLAG otherwise known as New Turtle in Japan:
http://www.sunflag.co.jp/english/company/company.html"
« Reply #4 on: August 20, 2019, 09:56:15 AM »
Which JIS screwdriver number are the most common screws, such as the brake reservoir cover screws? #1? #2? #3?
My guess is #2, but I wouldn't want to assume.
« Last Edit: August 20, 2019, 10:10:58 AM by Gryphon Rider » Logged
mello dude
Dayton Ohio
« Reply #5 on: August 20, 2019, 10:29:30 AM »
Dunno about specs, but a few years back I bought a Hozan set + the stubby and just remind myself to always use them on the bikes.... .
https://www.amazon.com/Hozan-D-69-Stubby-Screwdriver-Japan/dp/B007I6HF5W/ref=pd_bxgy_469_img_2/131-8651496-4106231?_encoding=UTF8&pd_rd_i=B007I6HF5W&pd_rd_r=97b6e340-83fc-4d53-a665-02a8f7ba77af&pd_rd_w=Zkgjp&pd_rd_wg=O3nAs&pf_rd_p=a2006322-0bc0-4db9-a08e-d168c18ce6f0&pf_rd_r=MXZDQJ050EN8JMDCWA3X&psc=1&refRID=MXZDQJ050EN8JMDCWA3X
https://www.amazon.com/Hozan-JIS-5-JIS-Screwdriver-Gen/dp/B003F63WI8/ref=sr_1_3?keywords=hozan+JIS+screwdriver+set&qid=1566325985&s=gateway&sr=8-3
They flat out work cooldude
Worth the money to have in the toolbox...
Bagger John - #3785
« Reply #6 on: August 20, 2019, 11:48:15 AM »
I got my 5pc Hozan set in the mail today.
The really long #2 standard driver works like a champ on the float bowl screws.  cooldude
Bought a #2 stubby as well.
Fazer
« Reply #7 on: August 20, 2019, 11:58:40 AM »
I have a set of JIS but rarely use them.  I saw somewhere that unless you see a small dimple on the screw head, they are not JIS and a regular Phillips will work.
Nothing in moderation...
Bagger John - #3785
« Reply #8 on: August 20, 2019, 12:23:30 PM »
The stock float bowl screws all have the dimple...at least on the set of carbs I'm looking at.
« Reply #9 on: August 20, 2019, 12:43:55 PM »
on the page
« Reply #10 on: August 21, 2019, 07:17:51 AM »
Thanks for the tip.  I just ordered #2 150mm and stubby screwdrivers through Amazon.
Paladin528
« Reply #11 on: August 22, 2019, 05:00:13 AM »
a #2 Phillips fits the fairing screws better than the JIS screwdriver.  Just sayin'
h13man
Indiana NW Central Flatlands
« Reply #12 on: August 22, 2019, 05:50:07 AM »
I use my Vessal JIS screwdrivers on most all Phillips screws now. Just seem to grip better but I still have my Snap On's for backup.
Bagger John - #3785
« Reply #13 on: August 22, 2019, 06:38:19 AM »
The several Craftsman #2s I have in my chest fit those very well but won't engage the carb bowl screws with sufficient grip to avoid damaging them.
This is why I'm always looking for more toolsa bigger rollaway cabinet... uglystupid2
