December 31, 2025, 09:08:52 AM *
Author Topic: Fuel gauge wiring harness Interstate  (Read 1014 times)
pokrovsky
« on: August 23, 2019, 06:49:35 AM »
I'll be installing an Interstate tank on my Standard and would like to get the fuel gauge installed as well.
I've already sourced everything I need except for the plug/socket that will connect the gauge to the fuel sending unit. Does anybody know the part number of that plug? Can it even be purchased separately (plug with pins so I can crimp it to the gauge harness)?
If not, does anybody have any other pointers how best connect the gauge to the sending unit so I retain disconnecting abilities like it's supposed to be from the factory?
Thanks very much!
Ramie
2001 I/S St. Michael MN
« Reply #1 on: August 23, 2019, 08:07:05 AM »
Not sure which connector it is but these guys have quite a few.
http://www.cycleterminal.com/motorcycle-connectors.html
Bagger John - #3785
« Reply #2 on: August 23, 2019, 09:04:10 AM »
The sender uses a 2-terminal locking male Hitachi connector w/ female pins. You'll need a female connector shell w/male pins.
Electrical Connection and a bunch of other vendors offer these.
pokrovsky
« Reply #3 on: August 23, 2019, 09:22:15 AM »
thank you very much!
is this the one?
https://electricalconnection.com/index.php/product/hitachi-2-pin-connector/
