December 31, 2025, 09:10:25 AM *
Author Topic: Stock I/S total wattage  (Read 1095 times)
HBFL
« on: August 28, 2019, 09:22:22 AM »
Anyone have a clue abt the total wattage used on a stock Interstate?
Steel cowboy
Spring Hill, Fl.
« Reply #1 on: August 28, 2019, 01:53:07 PM »
If you meant Amps
Use a V.O.M. set on DC Amps and the Amp clamp around the positive cable off the battery.
« Last Edit: August 28, 2019, 01:58:41 PM by Steel cowboy » Logged
2001 black interstate
2003 Jupiter Orange wing
indybobm
Franklin, Indiana VRCC # 5258
« Reply #2 on: August 28, 2019, 02:16:49 PM »
It would be dependent on what is turned on. Do you have running lights, amp for the radio, etc. Remember, all that current goes through one wire (red) off of the starter relay to power the whole bike unless you have a fused strip off of the battery to power accessories that have been added.
So many roads, so little time
VRCC # 5258
turtle254
Livingston,Texas
« Reply #3 on: August 28, 2019, 02:23:08 PM »
www.valkyrieforum.com/bbs/index.php/topic,105751.0.html
 this is a 98 std
turtle254
Livingston,Texas
« Reply #4 on: August 30, 2019, 11:57:22 AM »
Did you get an answer?
« Reply #5 on: August 30, 2019, 01:00:46 PM »
There's amps, volts, and watts.
I think the radio has 5 watts a channel.
I doubt that's what you were looking for, but all I got.
turtle254
Livingston,Texas
« Reply #6 on: August 31, 2019, 05:41:57 AM »
3 - 1157 bulbs on tail @ .59amps lower filament = 1.77 amps + lic. plate =1.8
headlight = 2.23amps + fog lights(2) 1.75 = 4amps
two turn/run front bulbs 1157 = 1.75 amps
gage light + small misc. + ignition = .5amps
This equals 8.2
_______________________________________________
That's 8.2 amps, so mine showing at  8 amps must be "OK",
even thou every one is telling me that's too high.
