November 13, 2025, 04:15:46 PM *
Author Topic: Final drive  (Read 1100 times)
Cleaver
Harrison, MI
« on: October 01, 2019, 11:47:08 AM »
Can the gearing from a 1500 GoldWing final Drive be removed and put in the case for a Valkyrie Drive?
« Reply #1 on: October 01, 2019, 01:53:53 PM »
If you can find a good 1500 wing final, you can remove the ring gear from
the wing and the ring gear from the Valkyrie... then (I got the shop at NAPA
to do this part for me) press the splines out of each ring gear and press the
good ones back into your Valkyrie ring gear...
Gizmo
Ottawa Canada
« Reply #2 on: October 01, 2019, 05:26:06 PM »
Might be a dumb question but....
I believe that the splines are tapered. How do you know which way to push them out/in?
« Reply #3 on: October 01, 2019, 08:32:47 PM »
Why are you changing gearing? Is your drive worn out? Or do you think the final drive is geared differently?
Cleaver
Harrison, MI
« Reply #4 on: October 01, 2019, 10:14:58 PM »
A friend has a Valkyrie that he thinks the final drive may have a problem, and I have a new unit from a 1500 Wing.
Dragon-6
Copperas Cove Texas
« Reply #5 on: October 02, 2019, 04:29:08 AM »
Don't they still sell the splines?  Press out the old and insert the new?
« Reply #6 on: October 02, 2019, 09:44:54 AM »
It's not hard to find a good wing final for $35 or $50... a new ring gear is $250. You'd
either have to "butcher up" the new ring gear by robbing the splines from it, or
install it using skill similar (surly not as hard) to rebuilding an automatic
transmission (shims and stuff)... RickyD rebuilt his with all new...
