November 13, 2025, 02:24:09 PM *
Author Topic: Front end suspension travel?  (Read 1012 times)
Big Rig
Woolwich NJ
« on: October 02, 2019, 12:10:24 PM »
What is normal?
How do you know when to replace?
Also how difficult is it to replace the springs on an IS???
What all is needed?
« Reply #1 on: October 02, 2019, 03:00:50 PM »
What all is needed?
I took my forks off and disassembled them recently.
I looked in the manual and noted the wear parts other than the seals (some bushings) and got those.
There's a special tool (or you have to have some workaround) for the left fork.
It is nice to have a seal driver, but I've made a fake one before with the right size of schedule 40
coupling.
http://www.valkyrieforum.com/bbs/index.php/topic,108179.0.html
Bagger John - #3785
« Reply #2 on: October 03, 2019, 06:02:26 AM »
Motion Pro has a driver tool for ~$45. I've seen them from other manufacturers for roughly the same.
Honda is proud of theirs ($100+) but I managed to get a used OEM tool from FleaBay for less than that of one of the aftermarket versions.
Forge
San Antonio, TX
« Reply #3 on: October 03, 2019, 07:45:26 AM »
Make sure that if you use a hammer to seat your seals ( I made the pvc one) that you ise a plastic mallet or strike against a block of wood angled towards the seal tool if using a metal hammer. You do NOT want to ping the fork!
