BigBF
Text message at 602-332-4872
Phx AZ
« on: October 06, 2019, 12:58:40 PM » |
I’m getting ready to hit the road this week. Since it’s almost winter and snow up north I’m going start go south route. I’ll need to stop at my parents place to help my parents to see about selling their house real soon. They will start retirement and traveling. then I’ll go back on road for south route until spring time to go up north. I hope to go for InZane this time. I will continue the trip all year until before winter in 2020 (before vote for president Trump 2020) FYI I still have those list before I had mild stroke. If any of you already sign up in 2018 and don’t need my service please update for cancel. If you need my service see the link in comments for sign up to be on list. Thank you! http://www.bigbf.com/signup/signup.htm
GiG
NEAR the "In 'n' Out Burger"
« Reply #1 on: October 06, 2019, 01:17:04 PM » |
Bill: Hope you are doing well and fully recovered! When you get around to it, my 97 needs carb rehab. You are welcome to take up residency in Belleville and schedule as many jobs for as long as you like here. I will monitor this thread to check your availability and hope to see you after the snow flies
Everything is - Nothing is .
When you come to a fork in the road - TAKE IT! (send it to OSS)
This isn’t Rocket Surgery
BigBF
Phx AZ
« Reply #2 on: October 06, 2019, 04:55:13 PM » |
Bill: Hope you are doing well and fully recovered! When you get around to it, my 97 needs carb rehab. You are welcome to take up residency in Belleville and schedule as many jobs for as long as you like here. I will monitor this thread to check your availability and hope to see you after the snow flies Sure I forget Which State is it?
BigBF
Phx AZ
« Reply #3 on: October 06, 2019, 05:00:19 PM » |
Update. I have not had time to edit the sign up form. Now on I will be working on valk in my trailer bec I’m not 100% from mild stroke to bring equipment in and out of trailer. I’ll need to have good flat parking lot or spot to keep level Any questions. Do ask Thanks
Valker
Wahoo!!!!
Texas Panhandle
« Reply #4 on: October 06, 2019, 05:03:26 PM » |
I sent in an update to the old list since I have three Valks now. If you can provide a guess on a time to come by here, I may add or subtract items depending on the time. I am planning to be at InZane with one, two, or all three Valks also. Not sure yet.
« Reply #5 on: October 06, 2019, 05:38:18 PM » |
Moved south since you planned the last trip. Calling Hattiesburg, Mississippi home now.
If you roll through this area, I'll have something for you to do (most likely a de-smog) and a flat place to park. But, timing will be ultimately important. Having some construction started so, will need to have an idea of when you might roll through (if you do roll through Mississippi).
« Last Edit: October 06, 2019, 06:09:37 PM by Rams »
VRCC# 29981 Learning the majority of life's lessons the hard way.
Pappy!
« Reply #6 on: October 07, 2019, 05:51:21 AM » |
Congratulations on recovering enough to get back to work! You are one tough cookie!
BigBF
Phx AZ
« Reply #7 on: October 07, 2019, 11:49:16 AM » |
I’ll be in Texas this month or November depend on route and works on valk.
BigBF
Phx AZ
« Reply #8 on: October 07, 2019, 11:53:25 AM » |
Thanks for update. Most likely after January depend if my parents need help.
BigBF
Phx AZ
« Reply #9 on: October 07, 2019, 11:55:23 AM » |
Thanks I don’t like sit and do nothing. I’m keeping busy as much as I can. Yes I know I gotta take easy...
« Reply #10 on: October 07, 2019, 12:47:07 PM » |
Thanks for update. Most likely after January depend if my parents need help. Hopefully, that Ford will get ya here..  And a bump for a damn fine Valkyrie Technician. Anyone else in the Hattiesburg area need something done while he's here? Rams
« Last Edit: October 07, 2019, 12:49:51 PM by Rams »
bagelboy
« Reply #11 on: October 07, 2019, 12:53:19 PM » |
Let me know when you're back in NY. I'll have you check everything out! Glad you are doing better!
1997 Valkyrie Tourer, 2005 GL 1800, 1987 GL 1200 Aspencade.
BigBF
Phx AZ
« Reply #12 on: October 07, 2019, 01:03:17 PM » |
Thanks for update. Most likely after January depend if my parents need help. Hopefully, that Ford will get ya here..  And a bump for a damn fine Valkyrie Technician. Anyone else in the Hattiesburg area need something done while he's here? Rams LMAO... Sure. Make sure they sign up to be on list... Thanks
BigBF
Phx AZ
« Reply #13 on: October 07, 2019, 01:04:54 PM » |
Yup will be there. Wondering are you ok with other valkyries come over for me to work on bec some of their place in NY are too small for my big rig.
Farside
Let's get going!
S. GA - N. FL
« Reply #14 on: October 07, 2019, 02:39:30 PM » |
Thanks for update. Most likely after January depend if my parents need help. Hopefully, that Ford will get ya here..  And a bump for a damn fine Valkyrie Technician. Anyone else in the Hattiesburg area need something done while he's here? Rams  I'm on the original list BF put out and I'm only 3 hours from Hattiesburg in Pan-handle FL.
Farside
BigBF
Phx AZ
« Reply #15 on: October 07, 2019, 03:24:14 PM » |
GiG
« Reply #16 on: October 07, 2019, 03:29:12 PM » |
Bill: Hope you are doing well and fully recovered! When you get around to it, my 97 needs carb rehab. You are welcome to take up residency in Belleville and schedule as many jobs for as long as you like here. I will monitor this thread to check your availability and hope to see you after the snow flies Sure I forget Which State is it? MICHIGAN
« Reply #17 on: October 07, 2019, 04:38:16 PM » |
Is my driveway still ok for you Need to.replace fan behind radiator on red bike and rear end service on my 01
Duffy
« Reply #18 on: October 07, 2019, 05:39:21 PM » |
Just saw this post, good news Big BF, how about Georgia? I need you for a carberator rebuild - just texted you before seeing this thread... Thanks
bagelboy
« Reply #19 on: October 07, 2019, 06:41:45 PM » |
NP! I have a long, flat driveway if you remember. When the time comes, anyone wishing to have BF work on their Valkyries up in the Catskills, come on by!
BigBF
Phx AZ
« Reply #20 on: October 07, 2019, 09:01:59 PM » |
Bill: Hope you are doing well and fully recovered! When you get around to it, my 97 needs carb rehab. You are welcome to take up residency in Belleville and schedule as many jobs for as long as you like here. I will monitor this thread to check your availability and hope to see you after the snow flies Sure I forget Which State is it? MICHIGAN oh I knew it. I had to ask LoL GiG is Gary right?
BigBF
Phx AZ
« Reply #21 on: October 07, 2019, 09:06:52 PM » |
I don’t carry that fan. You would need to order one. Your driveway. Nope my trailer are 40 feet long I’ll need flat spot to work bike in my trailer and your bridge 8’-9” my trailer is 13’ high And you can bring to bagelboy if he’s allowed? He’s north from you past I-80. I guess an hour from your place?
« Last Edit: October 07, 2019, 09:14:16 PM by BigBF »
BigBF
Phx AZ
« Reply #22 on: October 07, 2019, 09:08:12 PM » |
Just saw this post, good news Big BF, how about Georgia? I need you for a carberator rebuild - just texted you before seeing this thread... Thanks  Yup got your text message Thanks
BigBF
Phx AZ
« Reply #23 on: October 24, 2019, 12:11:08 AM » |
Update #1 and #2 in Coolidge AZ done #3, #4, and #5 in Sierras Vista AZ done Now I’m on Las Cruces NM for #6 working on...
Valker
Wahoo!!!!
Texas Panhandle
« Reply #24 on: October 24, 2019, 07:03:09 AM » |
How do we know what numbers we are?
Savago
« Reply #25 on: October 24, 2019, 09:29:25 AM » |
@BigBF: no California?
BigBF
Phx AZ
« Reply #26 on: October 24, 2019, 03:23:52 PM » |
@BigBF: no California?  Yep no body sign up but one near LA they could bring over at my place when I get home next year and calif Oregon and Washington are far span. Not like out in East in short span if long span my earning will probably loss for expense on long trip...
BigBF
Phx AZ
« Reply #27 on: October 24, 2019, 03:25:05 PM » |
When I arrived that’s the number after I worked on previous number.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #28 on: October 24, 2019, 04:49:17 PM » |
When I arrived that’s the number after I worked on previous number. Ok. I’m just trying to figure out when you’ll be stopping by here. I have to make plans to have the bikes and parts here.
BigBF
Phx AZ
« Reply #29 on: October 25, 2019, 11:50:59 PM » |
When I arrived that’s the number after I worked on previous number. Ok. I’m just trying to figure out when you’ll be stopping by here. I have to make plans to have the bikes and parts here. Panhandler Texas? That would be sooner I plan to go to El Paso then Pecos then Pampa then see my parents but could go panhandle on way. They need help sooner than later this is why I had to change insteaead go south until after my parents then head for south in Texas
BigBF
Phx AZ
« Reply #30 on: October 26, 2019, 04:30:15 AM » |
When I arrived that’s the number after I worked on previous number. Ok. I’m just trying to figure out when you’ll be stopping by here. I have to make plans to have the bikes and parts here. Panhandler Texas? That would be sooner I plan to go to El Paso then Pecos then Pampa then see my parents but could go panhandle on way. They need help sooner than later this is why I had to change insteaead go south until after my parents then head for south in Texas Oh never mind it was you in Pampa
BigBF
Phx AZ
« Reply #31 on: October 26, 2019, 10:45:50 PM » |
Update I’m in noth El Paso for #7
« Reply #32 on: October 27, 2019, 05:13:40 AM » |
Curious as to what you think your route might be? I fully realize that additional sign ups could and most likely will effect where and when you do what ever. For me, due to a current home renovation/remodel and adding on to the house, timing is very important. I would hate to not be able to host you due to being on generator power. Eventually, that is going to happen. Lots of changes happening here. I would also recommend to all taking advantage of Bill's visit to advertise with any other Valkyrie riders in their areas allowing Bill to stay in one place and work on their bikes versus Bill having to move short distances for small jobs. IOWs, bring the bikes to him when he's in your area. Rams
« Last Edit: October 27, 2019, 05:16:50 AM by Rams »
BigBF
Phx AZ
« Reply #33 on: October 31, 2019, 09:32:22 PM » |
Update I’m in Pecos Texas for both valk overhaul carb #8 and #9. Look like a bit change route I’m in Pecos Texas then going to Amarillo Tx then to Nobel OK then see my parents in Tulsa Ok to help them to sell stuff and set up for house sale sooner than I expected. After done help my parents I’ll be going to Texas.
« Last Edit: October 31, 2019, 09:38:46 PM by BigBF »
BigBF
Phx AZ
« Reply #34 on: October 31, 2019, 09:36:51 PM » |
Curious as to what you think your route might be? I fully realize that additional sign ups could and most likely will effect where and when you do what ever. For me, due to a current home renovation/remodel and adding on to the house, timing is very important. I would hate to not be able to host you due to being on generator power. Eventually, that is going to happen. Lots of changes happening here. I would also recommend to all taking advantage of Bill's visit to advertise with any other Valkyrie riders in their areas allowing Bill to stay in one place and work on their bikes versus Bill having to move short distances for small jobs. IOWs, bring the bikes to him when he's in your area. Rams Don’t worry about your remodeling I will not need anything from your place but lot for my trailer and I do have generator if I need to use. It probably later like in feb/March or so? Don’t worry about host maybe one or two if they don’t have big lot for my trailer. And I can go to them if they got big lot.
Gnarly
FlyinJenni2
Resume Speed,KY
« Reply #35 on: November 01, 2019, 02:16:31 PM » |
BigBF, If you are passing thru Western KY, there is room at the farm for your rig and the steaks are on me.
I've loved many bikes, over the last 52 years of riding, but this Valkyrie machine may have propelled me headlong into IDOLATRY....
Duffy
« Reply #37 on: March 04, 2021, 08:19:31 PM » |
Just came across this old thread from BigBF.
Last update was 11.1.2019, wonder if there was a different thread for his 2020 travels.
Any update on how his wife and family are doing/anything we can do?
« Reply #38 on: March 04, 2021, 09:26:21 PM » |
There are more recent threads than this one. I saw Bill's parents, wife, son, DIL, and SIL today. Most seemed to be doing ok, except his mom. His mom was pretty frazzled still and crying a lot. I was trying to get the trip expenses from her, but she couldn't quite pull herself together enough. I finally just told her to email it to me. If you want to help the family, Oss' PayPal fund is still open.
« Reply #39 on: March 05, 2021, 04:51:32 AM » |
here is the link fpr Duffy and anyone else interested I will update this weekend when I have time.. http://www.valkyrieforum.com/bbs/index.php/topic,115902.0.html
