December 31, 2025, 05:02:58 AM *
Author Topic: Lower Fork Corrosion  (Read 1641 times)
« on: October 27, 2019, 12:20:50 PM »
Wanting to polish 'em up while they are mounted on the bike.  What techniques are best?
« Reply #1 on: October 27, 2019, 03:18:01 PM »
         My 99 I/S also had a clear coat. I used some 800 grit paper then an S O S pad then I finished them off with the Purple California metal polish. Cleaned and shined now they look Almost like chrome. RIDE SAFE.
« Reply #2 on: October 27, 2019, 03:40:53 PM »
What techniques are best ?
Chrome fork covers.  Smiley
« Reply #3 on: October 27, 2019, 03:47:39 PM »
That clear coat is pretty tough.  I've used cans of carb cleaner to burn it off (not on the valk), but some kind of Naval Jelly or Zip Strip may be called for, although that could be hard on the aluminum (and your hands and eyes).
I sure wouldn't sand it off by hand.  It would be chemicals and/or power tools for me.
« Reply #4 on: October 27, 2019, 06:16:19 PM »
easy off oven cleaner will soften clear coat to easily scrap it off.  do small areas at a time, the cleaner will start to discolor the aluminum if left on two long. flush with water the area just removed.
https://www.caswellplating.com/buffman.htm
« Reply #5 on: October 27, 2019, 11:56:08 PM »
I've done a few valks with this method. It's easier if you remove the wheel and fender. Oven cleaner for 10 minutes, water wash and start sanding. I use 600 wet/dry to start. Graduating up to 1200. Then Mothers aluminum billet polish and a polish wheel on a drill.
« Reply #6 on: October 28, 2019, 07:21:03 AM »
         Reason I went with the non chemical removal was due to my breathing problems. Retired with time on my hands and + + I work cheap-fer myself!  2funny RIDE SAFE.
« Reply #7 on: November 04, 2019, 08:38:38 AM »
Thanks for the ideers.   I'd love to find a set of those fancy chrome covers at a reasonable price,  but I ain't the only one!   That said I'll probably try the oven cleaner,  scrub and polish technique. Think I'll wet a rag with that Easy Off to avoid overspray!
« Reply #8 on: November 04, 2019, 02:46:37 PM »
I've only ever used oven cleaner by spraying directly on the thing to be treated.  I think the reason they make it a foam is to allow it to sit on the target surface for enough time to allow it to do its work before it dries at the target surface.  If you spray it on a cloth, then wipe the cloth on the surface, the fluid will likely dry too soon to be effective.  It's the same reason why when treating mold on a vertical surface with bleach, you make a paste of bleach and baking soda, allowing it to sit on the surface long enough to do its job.
Lyle Laun
Calgary, Ab
« Reply #9 on: November 04, 2019, 05:39:50 PM »
I just sent you a pm
Regards
Lyle.....
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
F6BANGER
Albuquerque NM
« Reply #10 on: November 04, 2019, 08:06:13 PM »
Used set on ebay
https://www.ebay.com/itm/1997-2001-Honda-GL1500-Valkyrie-CHROME-FORK-LOWER-LEFT-RIGHT-COVER-COVERS/312806748282?epid=1628191673&hash=item48d4bc307a:g:tXMAAOSwCgldp31-
Bagger John - #3785
« Reply #11 on: November 05, 2019, 07:41:46 AM »
Do you wanna see the board cry?
Wait til I post pics of a set of those fancy chrome covers that have now been powdercoated gloss black.  2funny
Way back when, I bought enough spares of stuff like this that I can keep all the Valkyries in my garage looking brand-new, accessory wise. When a given part (or parts) gets to the point that it needs major cosmetic help, off to the coaters it goes.
In the case of my current I/S, I acquired enough rough but serviceable used parts to basically turn the entire thing black. Including the lower covers, caliper covers, fork tube covers...etc. The end result will be something that Honda should have done - and could have done, all with OEM parts and accessories - but didn't.
