December 31, 2025, 05:01:27 AM
Audiovox CCS-100
Topic: Audiovox CCS-100 (Read 1302 times)
Dragon4056
Waco, TX
Audiovox CCS-100
October 29, 2019, 11:48:57 AM »
I have read that the vacuum canister is not needed on our valks. Can anyone confirm this? I plan on using all 6 sources to supply the servo.
Thanks in advance yall
Re: Audiovox CCS-100
October 29, 2019, 01:22:12 PM »
Mine doesn't have one. It uses 2 of the vacuum ports with a check valve on them. Works great.
October 29, 2019, 02:20:17 PM »
Quote from: meathead on October 29, 2019, 01:22:12 PM
+1 same setup I have, been on there for quite a few years. Had all six originally but a few years back did away with all but two....one from each side. Works fine.
nogrey
Nampa, Idaho
October 29, 2019, 02:54:41 PM »
Itβs really your choice. I have one with a canister on my β97, and a 2001 IS without using the 2 check valves mentioned by others. My β97 with the canister has a much smoother, quicker and consistent response than the β01. They will work just fine without a canister, but much better with.
Avanti
Stoughton, Wisconsin
October 29, 2019, 04:07:57 PM »
Newer version does not use vacuum.
http://www.valkyrieforum.com/bbs/index.php/topic,86066.0.html
john_berry
October 30, 2019, 08:47:54 AM »
I use a very small vacuum canister and 1 vacuum port. It works just fine.
=> InZane XXV
