July 22, 2025, 01:25:07 AM *
Author Topic: Refreshing an older Valkyrie  (Read 696 times)
« on: November 04, 2019, 05:11:46 AM »
Been riding more miles the last few days than normal for not being on a road trip. The Valkyrie is so much fun to ride, like a new bike. So I thought to myself, self.....what have you done to it lately. Well, I came up with a list that may be a good list to make that older bike feel younger
-sync the carbs even if you think it’s running good. I finally did and my only regret is I didn’t do it sooner
-install the Jersey shifter!  Do it!
-bleed the clutch and brakes well, make sure  you do a total fluid exchange
-install new drive dampeners if it’s been 5 or 6 years or they are loose
-adjust the throttle cable so there is minimal slack. As long as the engine doesn’t rev itself when the bars are rotated stop to stop
- good tires and good pressure 40 / 42
-make sure the upper shock bushings are good
I did all these things this riding season. They are all ride-ability issues especially if more than one or two needs doing. It makes a big difference
« Last Edit: November 04, 2019, 05:39:25 AM by Chrisj CMA » Logged
« Reply #1 on: November 04, 2019, 05:22:01 AM »
 - check your levers for floppiness... There's a replaceable brass(?) bushing and a
non-replaceable one. I got a new bushing and installed some new levers I had for
a long time a month or so ago, how awesome my levers feel now... There's little
rubber boots at the lever pivots that need to be in good shape too...
« Reply #2 on: November 04, 2019, 05:47:37 AM »
That's good advice Jeff  cooldude
There's no way you could make her look any newer  Smiley
« Last Edit: November 04, 2019, 10:40:49 AM by Hook#3287 » Logged
