January 30, 2026, 03:42:47 AM *
Author Topic: Interstate Instrument Panel Lights  (Read 3176 times)
dmears
« on: December 04, 2009, 11:05:40 PM »
I am the proud owner of a 2000 Interstate that has recently burned out a couple of bulbs on the Tach and Speedo.  I havent been able to find any directions or procedure to replace.  I did see a posting about changing them out to the Sylvania bulbs but not how to do it.  Any help would be much appreciated.
Don
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: December 05, 2009, 01:42:54 AM »
Got to Dag's site, www.valkyrienorway.com, download the service manual.  That should help you.
Marty
Mr.BubblesVRCCDS0008
« Reply #2 on: December 07, 2009, 04:00:45 AM »
got mine at Oreilly's I think the bulbs are 70 or 74. I can't remember and the bike is at home but they're very small bulbs. Maybe someone else can chime in.
Joe Hummer
Arnold, MO
« Reply #3 on: December 07, 2009, 05:28:44 AM »
I tried all of the recommended non-oem replacement bulbs and didn't like the fit of any of them.  The replacement bulbs were much smaller than the stock bulbs and didn't fit in the holder correctly.  I felt they would rattle around too much and possibly fall out of the holders.  So, I ordered the stock bulbs from the dealer and put those in.
Joe
1999 Valkyrie Interstate
mjs1125
Eastern Shore, Maryland
« Reply #4 on: December 07, 2009, 03:06:12 PM »
I just changed the four bulbs on the instrument because the multi-display was had to see at night.   The bulbs I bought were Wagner #74's.  The whole instrument panel looks like new now.
Milt
Experience suggests it doesn't matter so much how you got here, as what you do after you arrive.
« Reply #5 on: December 08, 2009, 05:41:06 PM »
I didn't try any other bulbs.  I just ordered stock ones and used those.  It looks like new now.
Same thing Joe did.
Hay  Cool
Ronnie Reeves
My 5th. valkyrie
Manchester Tn.
« Reply #6 on: December 12, 2009, 09:39:00 AM »
Thats strange because on my Interstates they are soildered in . The hole cluster had to be removed. Was a prety good job.
Ronald Reeves
« Reply #7 on: December 12, 2009, 10:18:47 AM »
That is really strange!  The bulbs should be pushed into a bulb holder (the bulbs are a bayonet style) and the holder is then a "push turn" that holds it in place.
Sounds like someone couldn't find the correct replacement bulb and did a little modifying.
Ronnie Reeves
My 5th. valkyrie
Manchester Tn.
« Reply #8 on: December 17, 2009, 07:45:13 PM »
No I stand corected it was a turn signal bulb and they are soldered in .
Ronald Reeves
