December 30, 2025, 03:09:14 AM *
Author Topic: Running a CT with 11-1/2" shocks  (Read 1403 times)
2KVISRiderDan
Valrico, Fl.
« on: November 17, 2019, 04:42:54 PM »
Are any of you Dark Siders running a CT on the rear of your Valk with 11-1/2" shocks? I would like to lower the rear of my 2001 Interstate which is a permanent SoloValk but really like running Dark Side.
« Last Edit: November 17, 2019, 04:44:42 PM by 2KVISRiderDan » Logged
2005 Yamaha Midnight Star SOLD
1997 Yamaha Royal Star Std SOLD
2000 Blue & Grey Interstate
2001 Black & Champagne Solo Interstate
1998 Blue & Cream Valkyrie Standard Roadsmith Trike
1997 Black Standard
« Reply #1 on: November 18, 2019, 03:03:45 PM »
You shouldn't have any problem doing that. I wouldn't go with anything taller that a 60 profile. A 55 profile will affect the rpm's a few hundred, but is definitely a shorter tire.
2KVISRiderDan
Valrico, Fl.
« Reply #2 on: November 18, 2019, 06:52:02 PM »
Thanks Ricky. I am currently running a Hankook Optimo 195/60 R16 on my other Interstate with 13" Progressive 440 shocks.  I took a look at the clearance on it today and it looks like the 11.5" shocks will work fine after doing the nut cage mod. I just pulled the trigger on the used 11.5" Progressive shocks with the optional heavy duty springs.
1997 Black Standard
TrapperAH1G
Toledo, WA
« Reply #3 on: March 05, 2021, 11:45:55 AM »
I realize this is an older post, but wondering if the OP is still here......how did the 11.5 shocks work out?  I'd like to do the same to mine.
« Reply #4 on: March 06, 2021, 09:48:18 AM »
lowering that low will cause the tire to hit the fender were it clears the upper shock cross frame support bar when hitting bumps.
I hit it with a 205/65-16 tire and with the OEM I/S shocks set on too low of a setting.
« Last Edit: March 06, 2021, 09:52:06 AM by 98valk » Logged
