December 31, 2025, 03:18:19 AM *
Author Topic: UHP tire  (Read 1999 times)
Gondul
VRCC #408
Central Florida
« on: November 24, 2019, 06:06:17 AM »
Currently running an old Cooper 2xS which needs replacing due to age.  Anyone running an UHP tire? Searched through the group but found zero info... not interested in an all weather  tire, winter tire, or truck tire.
Living in central Flori-duh so the cold isn't an issue. Much more interested in the larger contact path and wet weather performance than longevity.
205/55 seems to be the only size with anything of a selection (which is fine), some have a more rounded profile than others (considering the Cooper was flat, it is an improvement) so far I've found the following:
General G-Max RS
Dunlop Dirrezza DZ102
Bridgestone Potenza RE-71R
BFGoodrich G Force Sport Comp2
Yokohama Advan Fleva V701
Kumho Ecsta SPT
Leao Lion Sport UHP (this is the only one I'm iffy on)
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
« Reply #1 on: November 24, 2019, 11:45:00 AM »
Nice rounded shoulders  cooldude
Leao Lion Sport UHP
Good price as well.
Gondul
VRCC #408
Central Florida
« Reply #2 on: November 24, 2019, 01:57:52 PM »
I did see that it likely had the 'roundest' profile out of all of them... price seems to be $10 within the General G-Max RS which was the tire I was leaning towards.  So I'm guessing you run this tire and like it?
John Adams - 1797
« Reply #3 on: November 24, 2019, 04:42:50 PM »
I use a Champiro VP1.
I have one waiting in the garage to replace the one that's on my bike. The next tire could well be a Leao Lion.
Six-Cylinder Hooligan
« Reply #4 on: December 05, 2019, 04:30:56 PM »
I've been running a 195/60-16 for the last few years. Kumho Escta PA-31 & Yokohama Avid Ascend are both good. I'm currently on the Yokohama and it's about $10-$20 more than the Kumho but seems as if it's going to last much longer. FWIW, I usually got about 18k from the Kumho.
For a budget tire, I've been eyeing the Federal Formoza AZ01. It's only $50!
The tread pattern on it looks very similar to the Avid Ascend.
https://www.amazon.com/dp/B00UAJ4908/?coliid=I10ZO3CR56ZSBL&colid=2P2PYAE0PECB3&psc=1&ref_=lv_ov_lig_dp_it
« Reply #5 on: December 28, 2019, 06:01:59 PM »
no experience, but that federal formoza but in 14 inch size for my suzuki burgmann 650 is the one going to late next year when my bridgestone rear cycle tire is shot.   at least with the scooter no rear maintenance needed can stay on for 8+ years probably will last much longer than the bridgestone cycle tire at 10K or so per cycle tire change.
« Reply #6 on: January 01, 2020, 12:48:04 PM »
Zeetex CT-1000.   cooldude
Gondul
VRCC #408
Central Florida
« Reply #7 on: January 01, 2020, 03:01:04 PM »
Thanks, but that is a truck tire and not an Ultra-High Performance tire...
John Adams - 1797
« Reply #8 on: January 01, 2020, 04:48:36 PM »
He probably has many miles on it and would not recommend it if it didn’t perform. Just because it says a truck Tire dont mean squat.
And BTW you live in Florida where there are 18 curves every 311 miles so why in double hockey stcks would you ever need an ultra high performance tire?
Just asking for the next time I am carving up the twisties in Florida.  Roll Eyes
Also You say you are replacing your tire due to age? So it seems no matter what tire you put on it wont really matter because you will replace it also not because it is worn out but past its shelf life. Just sayin.
« Last Edit: January 01, 2020, 04:57:03 PM by Bighead » Logged
« Reply #9 on: January 01, 2020, 08:56:02 PM »
I like it enough that it's on both my bikes.  Traded an Austone for one of 'em.
N0tac0p
« Reply #10 on: January 02, 2020, 02:41:37 AM »
general question.  having mixed tires, ie a car tire on back and an MC on front make it handle funny?  i mean i think i have read on hear folks saying don't mix, dunlop and metz or radial and......
so i am interested in  some of these tires (especially when my rear cost 270), but have the above concern
« Reply #11 on: January 02, 2020, 02:51:05 AM »
I've been running various car tires on back, rear tires on front with good effect. I've pretty much settled on a Radar Argonite 195/65 and a Michelin rear Pilot Activ 150/70 on the front.  Smiley
N0tac0p
« Reply #12 on: January 02, 2020, 03:13:22 AM »
thats the other thing, why put a rear on the front vs a front on the front  and is it mounted in reverse
« Reply #13 on: January 02, 2020, 08:28:22 AM »
Rear motorcycle tires (new) have like a third to two fifths deeper tread than new fronts.
And are reversed on the rim because of radial (or bias) cord stacking on hard braking (not water dispersal).
Avanti
Stoughton, Wisconsin
« Reply #14 on: January 02, 2020, 12:26:00 PM »
Which size are you using?
« Reply #15 on: January 02, 2020, 01:33:54 PM »
195/65
Avanti
« Reply #16 on: January 02, 2020, 02:51:59 PM »
Thank you.
« Reply #17 on: January 02, 2020, 03:38:58 PM »
general question.  having mixed tires, ie a car tire on back and an MC on front make it handle funny? ...
Be careful what you assume from others' experiences.  Folks tend to say car tire as if they all fall into the same category.  They don't.  There are many different styles of non-motorcycle specific tires.  Some are very good and some are very bad about making a motorcycle handle.  If you get a chance ride on someone else's motorcycle equiped with the tire you think you'll buy.  If you're pleased then move ahead.  If not, keep searching.
