December 31, 2025, 05:01:43 AM
Won't start
Topic: Won't start (Read 1130 times)
Colin
My old job
Orba, Spain
Won't start
November 30, 2019, 06:59:43 AM »
I am sure this has been asked and answered before but I can't find a thread.
Battery fully charged, not hydralocked, in neutral, bank angle sensor OK. Press the starter button headlight goes out (relay controlled as per previous recommendations) but starter doesn't turn over. Fuse in starter relay OK, contacts not burnt. Short the starter relay out with a spanner and it starts.
Any suggestions please as I was looking forward to a ride tomorrow morning.
Colin
VRCC Espana
My Bumble Bee re-build
Re: Won't start
November 30, 2019, 08:01:52 AM »
My normal smart ass question.
Did you hit the kill switch by mistake?
Not the first to do it
Re: Won't start
November 30, 2019, 08:08:55 AM »
I don't know if your on an I/S or something else. In the fairing of an I/S is a red square plug. My starting issue was in that red square plug. Loose contacts in that plug. While I'm not sure I believe the Standard and the Tourer have something similar in the head light bucket. You stated the contacts in the starter switch aren't burned BUT are the contacts clan and springs installed correctly? RIDE SAFE.
Re: Won't start
November 30, 2019, 08:53:02 AM »
Starts button cleaning is due. (At least that’s my guess)
Re: Won't start
November 30, 2019, 08:57:58 AM »
I agree with meathead. Do the starter switch maintenance
F6Dave
Wiggle the Switch
November 30, 2019, 09:27:25 AM »
Sometimes you can finesse the starter switch to verify it needs cleaning. Mine started acting up now and then when the bike was only a few months old. I complained to the dealer and he didn't have a clue. He replaced the battery under warranty just in case that was it. All seemed fine until it happened again.
When it did act up I learned I could start it by pressing the switch from a corner, or wiggling it as I pressed it. I finally heard that cleaning the switch would solve the problem. Since I did that it hasn't given me any trouble in 20 years, and 175,000 miles.
Colin
My old job
Orba, Spain
Re: Won't start
Reply #6 on:
November 30, 2019, 10:35:44 AM »
Thanks I will try the starter switch I did clean it about 6 years ago so may be due another cleaning. Not the kill switch though I did check that as I did that once
Colin
VRCC Espana
=> InZane XXV
