November 20, 2025, 01:34:45 PM
How to undo the plastic clips on handlebars?
Topic: How to undo the plastic clips on handlebars? (Read 2180 times)
Colin
My old job
Orba, Spain
December 08, 2009, 04:59:03 AM »
I am trying to take the handlebars off as part of my re-build. Does anyone know how to undo the plastic clips that retain the cables and brake and clutch lines? I don't want to wreck them by doing the wrong thing. I have tried bud can't seem to get then apart.
TIA
Colin
VRCC Espana
My Bumble Bee re-build
Re: How to undo the plastic clips on handlebars?
December 08, 2009, 05:44:40 AM »
They should just unsnap. Make sure there not cold and get a little screw driver in between them and snap them open. To get them off the bars they just slide off. You might have to push a small tab to get them to slide. Get a good light and look. Its pretty easy to remove them.
Colin
My old job
Orba, Spain
December 08, 2009, 06:23:37 AM »
Thanks I'll give it a go.
I didn't want to force them and snap them.
Colin
VRCC Espana
Valker
Wahoo!!!!
Texas Panhandle
December 08, 2009, 11:27:21 AM »
If you kind of twist them, you can see how the one part slides out of the other. It is easier to 'unslide' them than to pop them out.
Colin
My old job
Orba, Spain
December 08, 2009, 01:38:49 PM »
Thanks guys that's tomorrows job. I'll let you know how I get on.
Colin
VRCC Espana
Thunderbolt
Worthington Springs FL.
+1 on sliding them apart
December 08, 2009, 03:23:22 PM »
Can't remember exactly the process, but once you have done one it will be easier. Maybe push one side one way and the other the opposite.
Sodbuster
Reply #6 on:
December 08, 2009, 05:20:17 PM »
Try using a hair dryer to warm them up so they're more pliable and easier to undo ....
VRCC # 30938
Dear God, Seriously .... Thanks for creating beer. You rock !!
Tropic traveler
Silver Springs, Florida
Reply #7 on:
December 08, 2009, 05:32:57 PM »
If you do break them {easy to do!} they are still available from Honda, part # 90690-GHB-701. I bought 2 from HDL, $2.50 each.
'13 F6B red for Kim
Colin
My old job
Orba, Spain
Reply #8 on:
December 09, 2009, 06:27:35 AM »
Thanks guys I managed to undo all four without breaking one of them.
Surprising what a torch and magnifying glass allow you to see
For anyone else I found that a small awl fitted under the catch easier than a screwdriver and off they came.
Colin
VRCC Espana
=> InZane XXV
