December 31, 2025, 03:18:16 AM
Delco 400 se oil 15W/40
Topic: Delco 400 se oil 15W/40 (Read 1239 times)
January 30, 2020, 09:39:34 AM »
I could get some free. Should I use it in the Valkyrie?
Barnstormer
Re: Delco 400 se oil 15W/40
January 30, 2020, 02:28:34 PM »
Go for it. I use Shell rosella 15/40 in my valks and in a BMW R1200.
wirral_biker
Wirral, ENGLAND
February 01, 2020, 09:53:29 AM »
Gear change might be a tad more clunky before fully warmed up.
I will never learn, on my 4th Valkyrie now !
February 01, 2020, 10:21:08 AM »
CK-4 or older CJ?
CK is/was low on phosphorus needed by the gears for wear prevention. Early CK-4 Delo.
http://pqiadata.org/Chevron_Delo_400SDE_15W40.html
if it meets the new Ford spec WSS-M2C171-F1 , it will have enough phosphorus.
https://www.fcsdchemicalsandlubricants.com/main/product.asp?product=Diesel%20Motor%20Oils%20Meeting%20Ford%20WSS-M2C171-F1&category=Motor%20Oil
Led
Wisconsin
February 03, 2020, 11:20:17 AM »
YUP!!! I use the Mobil 1 Diesel product in the 5w/40 weight........it comes in 4 quart containers.......PERFECT!!!
But.....15w at start up? It ain't a Harley!!!! I would not use it........
https://www.walmart.com/ip/Mobil-1-5W-40-Turbo-Diesel-Truck-Motor-Oil-1-gal/17128879
Last Edit: February 03, 2020, 11:31:57 AM by Led
=> InZane XXV
