December 31, 2025, 03:17:08 AM *
Author Topic: Brake lights staying on-Update-brake light not working  (Read 1286 times)
WoodyFL
Ocoee, Fl
« on: February 01, 2020, 01:10:40 PM »
Need some help. Had a guy come up next to me and told me my right brake/tail light was out. Had time today to replace it. I had replaced all taillight and brake lights with LED's last summer, so the problem didn't begin there. The bike came with the ''Back Off' mod when I bought it. Also of note I had installed Jersey's Signal  Boss when it first came out. The auto cancel feature of that stopped working a few weeks ago, however I don't think it's tied into the brake lights.
The brake lights would flash a few times then go solid and now after putting in the new bulb it looks like the brake lights are on all the time. Did a continuity test on the switches and they seem fine.
Any ideas?
UPDATE
Ran up to Advance Auto and picked up a standard 7743 bulb so I could actually tell if the dual filament was working as the LED's are so damn bright I had assumed the brake light was on steady. It actually is the opposite. Can't get the brake lights to come on. Tried both the front and the rear switches and nothing.
Guess the next step is to remove the mods one at a time and see what happens. Trial and error so they say.
Bob
« Last Edit: February 02, 2020, 07:02:19 AM by WoodyFL » Logged
2000 Blue/Silver I/S
Ocoee, FL
« Reply #1 on: February 01, 2020, 01:46:21 PM »
With a pure stock setup (and regular bulbs), my brake light took to staying on about 5 seconds after my foot came off the pedal.  It was the brake light switch down there; it needed a good cleaning and lube, and then readjusted with the wheel.  Fixed my issue.
Avanti
Stoughton, Wisconsin
« Reply #2 on: February 01, 2020, 01:56:36 PM »
Might want to check with Jersey, but I believe if the Signal Boss looses power you need to reset your auto cancel feature.
Although very little power is being used, the Signal Boss is using power even when your bike is not running.
You can disconnect the power to the Signal Boss and than reconnect and reset to see if it will help.
« Last Edit: February 01, 2020, 01:59:56 PM by Avanti » Logged
« Reply #3 on: February 13, 2020, 05:36:45 PM »
I had my hand brake switch fail. Replaced, kept the old one as a spare after cleaning it up.
The foot brake, can't remember what happened or what I did to fix it, but I adjusted the switch unit, and lubed the pedal pivot bolt. I think it was sticking down, manually lifted the pedal, which is why I lubed the pivot. Brake light never came on, because it never turned off.
longrider
Vernon, B.C. Canada
« Reply #4 on: February 14, 2020, 05:34:31 AM »
Gordonv
You are right.  It should be a yearly maintenance item to remove and lube the rear brake pedal.  Mine would not return and the brake light stayed on
WoodyFL
Ocoee, Fl
« Reply #5 on: February 14, 2020, 07:35:56 AM »
I actually disconnected both switches and I'm still getting power to both leads of the front brake switch. I was able to rule out the Back Off module. Finally got a colored wiring diagram and I'm going to have to track down where the problem is. Gonna be a long weekend.
Bob
Ocoee, FL
Jersey
VRCC #37540
Southern Maryland
« Reply #6 on: February 14, 2020, 09:48:17 AM »
Bob
Hey Bob,
I'll shoot you and email.
Jersey
Jersey
