December 31, 2025, 03:18:15 AM *
Author Topic: Petcock Assy  (Read 1600 times)
jackt
This is one of my babies
Central Kansas
« on: February 09, 2020, 04:32:11 AM »
I have a 1997 GL1500C2 (title says).
The petcock started leaking and I'm confused with partzilla fuel tank diagram.
They list 4 different ones.
Which one do I need want complete valve.
It's leaking where Honda pressed the left side on with little rivots??
PETCOCK ASSY., AUTO
16950-MZ0-003
Ships in 2 to 3 days
PETCOCK ASSY.
16950-MZ0-013
In Stock
PETCOCK ASSY.
16950-MZ0-023
In Stock
PETCOCK ASSY., AUTO
16950-MZ0-033
In Stock
Jack
« Last Edit: February 09, 2020, 04:35:08 AM by jackt » Logged
2006 Shadow
1999 Standard (fast black)
1997 Bumblebee
2005 Gold Wing trike
longrider
Vernon, B.C. Canada
« Reply #1 on: February 09, 2020, 05:33:44 AM »
The part numbers are updated from time to time.  That part ending in 033 is correct
« Reply #2 on: February 09, 2020, 05:34:24 AM »
COVER SET, PETCOCK
16953-MV9-000
by Honda
$40.00
This is what you need to rebuild the OEM petcock .
Takes some mech skill.
Some will suggest swapping it out with a aftermarket Pingle.
I've always used the cover set.
If you going to get a whole new one, any of the ones listed will work.
I believe Honda used the same petcock for all models, all years.
« Reply #3 on: February 09, 2020, 05:36:26 AM »
COVER SET, PETCOCK
16953-MV9-000
by Honda
$40.00
I've always used the cover set.rom they
He said it was leaking from the switch side. Not the vacuum side that the cover set fixes
« Reply #4 on: February 09, 2020, 05:46:23 AM »
COVER SET, PETCOCK
16953-MV9-000
by Honda
$40.00
Yeah, Jeff, guess I missed that detail.
So the ball bearing must not be setting correctly?
-mike-
Germany
« Reply #5 on: February 09, 2020, 06:54:55 AM »
Rebuilding the switch side is a nightmare.
Theres no easy set available.
Drilling the rivets, finding the right aftermarket o-rings, reassembly with bolts and nuts.
Time for a new petcock. Been there, too.
-mike-
ridingron
Orlando
« Reply #6 on: February 09, 2020, 09:48:49 AM »
The parts fish I use, partsfish.com, has those numbers but are crossed through with the 033 number following. That is to show the superseded numbers.
https://www.partsfish.com/oemparts/a/hon/5054120df870021c54bee66b/fuel-tank
« Last Edit: February 09, 2020, 07:21:11 PM by ridingron » Logged
Jruby38
Oxford Mass.
« Reply #7 on: February 09, 2020, 09:53:17 AM »
The only thing worse than the OEM petcock is the wrinkle plastic chrome.
« Reply #8 on: February 09, 2020, 10:00:40 AM »
I'm 100% happy with my OEM petcock... YMMV  Smiley ...
There's an easy vacuum test on this shoptalk page that I always use to help me
have confidence that I installed my coverset properly...
http://www.valkyrieriders.com/shoptalk/petcock.htm
« Reply #9 on: February 10, 2020, 08:19:54 AM »
As I see it, the biggest problem with the OEM unit is the relationship of the "off" function being between the "on" and the "res".
Most all good, thought out, petcocks have the "off" at the end of the movement of the selector.
The OEM unit does not, but rather between both of the "on" functions.
This can really be a problem because you are dependent upon you sensitivity (touch) to know if it is off or not.
So combine this with a stiffly turning selector, and a "let me check that again" personality, can certainly lead to a problem to where you are totally depending upon properly working float bowl valves for your security.
And we all are fully aware of the fallacy of that argument being that there are six float bowl valves we have to depend upon.
That is the total reason that I have spent the money for a high quality fuel stopcock.
Peace of mind is definitely worth the expenditure.
« Last Edit: February 10, 2020, 01:17:14 PM by Ricky-D » Logged
Gondul
VRCC #408
Central Florida
« Reply #10 on: February 10, 2020, 12:35:42 PM »
Got stranded three times within two years of buying the bike back in '98 due to the crappy OEM Petcock, the first time was within 10 miles of riding it off the lot...replaced with a basic valve shut off...zero issues.
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
