November 20, 2025, 03:13:37 PM *
Author Topic: Buzz bolt  (Read 2163 times)
SANDMAN5
Mileage 65875
East TN
« on: December 09, 2009, 06:58:03 PM »
Anybody ever broke one? I was getting some buzzing in my handlebars
at 2000-2500 rpm so I tightened the buzz bolt. Got maybe 1/2 face
tighter. Should I go more? Still tingles a little in the same rpm range but
it helped a lot. Just don't wanna take a chance on breaking anything.
« Reply #1 on: December 10, 2009, 03:54:15 AM »
That is a tool steel hardened bolt.  I pulled on my rachet as hard as I possibly could.....and very occasionally in temp changes, I still get some noise.
However, my buzzbolt made noise, but not perceived vibration.  I still get harmonic vibration in my throttle grip (iso grips) at sustained high speeds/rpms which causes my right hand to go to sleep.  Only solution is gloves/throttle boss/throttle lock.
PAVALKER
Pittsburgh, Pa
« Reply #2 on: December 10, 2009, 08:06:12 AM »
I have heard the term Buzz Bolt, but don't seem to remember it being on the handlebars???   Or am I thinking of something else....?
John
SANDMAN5
Mileage 65875
East TN
« Reply #3 on: December 10, 2009, 08:42:57 AM »
No, it's actually close to the radiator, but the vibration(to me) is felt in the
handlebars, and barely in the footpegs. Maybe "tingling" is a better word than vibration?
It's a lot better than it was after I tightened the buzz bolt, I just wanted to know
if I could tighten it more. cooldude
« Reply #4 on: December 10, 2009, 09:27:30 AM »
I hit mine with the air gun set on 200#.  Ain't rattled since.
Oh, that was in early 1998 I did that........
quexpress
Montreal, Québec, Canada
« Reply #5 on: December 11, 2009, 10:39:03 AM »
I did mine in 2002 I guess and it hasn't buzzed since. No ... I didn't break it LOL!
After examining the spacer tube that is over the bolt, I realized that it was a bit too short. Since the vertical frame tubes are quite large, there is no way in hell that I could tighten that bolt enough to take up the slack.
I have therefore:
1. Filled up the tube with silicon RTV (prevent buzzing)
2. Added a washer (or 2 ... I forget) between the buzz tube and the frame tubes
3. Tightened the bolt quite a bit ... but not breaking it.
No more buzz ...  Cool
I still have a full deck.
I just shuffle slower ...
« Reply #6 on: December 11, 2009, 12:18:48 PM »
Que, that is exactly the little trick that is necessary on some bikes.  That bolt sleeve inside the frame may rattle despite 200ftlbs on the bolt/nut which are outside the frame.
