March 27, 2026, 01:14:35 AM *
Author Topic: Non Valk Carb Issue  (Read 451 times)
pais
One more turn should do it!
Kent, Ohio
« on: March 22, 2020, 06:32:21 AM »
https://www.toro.com/en/parts/partdetails?id=3047
After putting new belt on snow thrower last night. I decided to drain carb of gas. While doing that, I wiped down carb bowl and around the ring of the carb. Just as I did this, a spring/clip fell out  crazy2. I have no clue where it fell from. I found it on parts fiche, but still do not know where it goes? It is #'s 30 & 31. Anybody read the fiche better than me? Thanx!
signart
Crossville, Tennessee
« Reply #1 on: March 22, 2020, 07:58:07 AM »
That has to be what raises/lowers the needle, so that coil spring & pin goes in between the dog ears and then the clip as oriented in diagram. The groove in the needle would catch on the curl of the clip.
