jnicks01
« on: May 26, 2020, 08:50:37 AM » |
I have been putting off the timing belt replacement till last on my post purchase maintenance list. Honestly, it somewhat intimidates me, but it is time to knock it off my list. Only 36k miles, but I want the piece of mind as they are cheap. I'll check the pulleys, etc. while in there. Can't be more involved than the splines, which were not a hard task to service for me.
Question is to set the tension, is a tool really needed to achieve the 4.4lbs of pressure? Or do you guys just go by "feel"? Other tricks?
I want to scoop out your brains and eat your knowledge.
« Reply #1 on: May 26, 2020, 09:02:50 AM » |
The springs are there to set the tension. Make sure the bolts to the tensioners are just tight enough to allow easy movement but no wobble in the mounting plate. Push on the tensioners a few times and see that the springs are doing their thing and that should be good to go.
jnicks01
« Reply #2 on: May 26, 2020, 09:12:07 AM » |
Thanks ChrisJ,
I did see that somewhere too on this forum. Seems easy enough...
« Reply #3 on: May 26, 2020, 09:18:06 AM » |
Also Make cursed SURE the static timing marks are Aligned PROPERLY. These Are interference engines. Before buttoning everything up and with plugs Out and all torques set turn the engine thru a couple times with a socket setup on the center bolt-crank shat bolt. I took my time and reread the instructions several times Before tear down. I have a Honda Valkyrie manual and a Clymer Valkyrie manual. Belt replacement is also covered in some posts here and there is a picture segment somewhere that is also loaded with good info on belt replacement. The entire procedure is Actually pretty straight forward. And there Is a wealth of people here who have been there done that got the T-shirt!  RIDE SAFE.
steve1433
« Reply #4 on: May 26, 2020, 03:50:29 PM » |
A good universal guide with ANY cam belt for tension has always been to be able to turn the belt at the middle of the longest point between the pulleys 90 degrees.....by using your fingers only.
-mike-
« Reply #5 on: May 26, 2020, 07:55:41 PM » |
↑ This.
jnicks01
« Reply #6 on: May 27, 2020, 05:19:00 AM » |
Old2soon. I think I have read both roughly 50 times. No exaggeration. And you are correct, many other great tips on here that I've bookmarked.
Steve. That is a great tip too! I've never heard that, but I'll add it to my list of tasks!
Everything else I've done hasn't blown up yet, so hopefully i'm doing something right.
« Reply #7 on: May 27, 2020, 09:11:12 AM » |
Whenever I hear this word TENSION in conjunction with the timing belts, I cringe.
Those springs are engineered to correctly adjust the timing belts.
All they effectively do is to remove any loose slack,
that is all they are intended to do.
If, in attempting to adjust the tensioner pulleys, in your zeal, you help the springs a little,
The tensioner pulleys in no time will fail.
Honda doesn't even put a life expectancy on the belts.
All Honda says is to inspect them.
The timing belts are probably the least stressed items on the whole bike.
Proceed accordingly.
mello dude
Dayton Ohio
« Reply #8 on: June 02, 2020, 03:17:14 PM » |
Is there a good video on the belt change? I just pulled the cover off for look see. Can't be that hard, but I want to make sure I understand everything before I decide to go ahead. I know timing is everything. As a btw... I am a automotive engineer by training, and looking at the large gear pulleys on the ends are a stamping part. Very impressive to design and produce those parts.
* There's someone in my head, but it's not me....... * Mr. Murphy was an optimist.... * There's a very fine line between Insanity and Genius..... * My get up and go, must have got up and went.....
« Reply #9 on: June 04, 2020, 11:15:41 AM » |
It's been a while since I've looked over the items. I found something nice in the GW GL1500, I don't recall in the Valkyrie. Remove the spark plugs. This way you aren't fighting the compression trying to turn the motor. When done, just remember that all important turning the engine over by hand a few 720' to get all those cycles, and insure there is no interference, before even attempting to start the engine. Someone mentioned that even 1 tooth off can be a few degrees, so again, make it right. GW, remember, only the mechanical side is the same, no plastic. https://goldwingdocs.com/forum/viewtopic.php?f=14&t=9774
« Last Edit: June 04, 2020, 03:34:32 PM by gordonv »
« Reply #10 on: June 04, 2020, 02:41:22 PM » |
If there is a noticable buzz when done then the belt may be to tight, but a very slight buzz is ok. It should go away in a few rides and settle down to no noise.
mello dude
Dayton Ohio
« Reply #11 on: June 06, 2020, 08:27:21 PM » |
Geez, the OEM belts are 70 dollars each, plus other parts and this gets spendy fast. What are alternative sources to save a few bucks?
6adan
« Reply #12 on: June 07, 2020, 04:28:54 AM » |
Gates T275 is one.
1970 CB750JDM, 1975 GL1000, 1979 GL1000 semi cafe, 1979 CBX, 1995 GL1500 SE, 2008 GL1800 trike. Several more not running yet.
« Reply #13 on: June 07, 2020, 08:53:12 AM » |
There should be no sound whatsoever from the running belt(s) If you have sound, something is not correct. ***
« Reply #14 on: June 07, 2020, 10:24:23 AM » |
On Shoptalk, the generic parts page. http://www.jkozloski.com/generic_parts.htmI bought a set of Gates for $45 for the pair. Others have claimed $16 ea, I think on Amazon. Gates is the supplier (manufacturer?) for almost all belts. Why pay a dealer double for the same item.
« Last Edit: June 07, 2020, 07:40:08 PM by gordonv »
mello dude
Dayton Ohio
« Reply #15 on: June 07, 2020, 02:32:26 PM » |
« Last Edit: June 08, 2020, 04:45:12 AM by mello dude »
jnicks01
« Reply #16 on: June 08, 2020, 05:37:26 AM » |
that is the correct one. you need 2
« Reply #17 on: June 08, 2020, 06:21:16 AM » |
When I bought Gates I remember them being made in Germany. I would not buy Chinese belts
indybobm
« Reply #18 on: June 08, 2020, 06:27:28 AM » |
Is there a Gates company in China or are these rip-offs
So many roads, so little time VRCC # 5258
mello dude
Dayton Ohio
« Reply #19 on: June 09, 2020, 10:10:52 AM » |
Gates is an international company, chances are they have manufacturing plants in Germany, England, US and China.
baird4444
« Reply #20 on: June 09, 2020, 02:36:56 PM » |
Timing Belts Gates # 275 Napa # 250275 Goodyear - #40275
Riding a motorcycle isn't like driving a car.... - ya gotta be SOBER!
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ "You can't drink all day if you don't start in the morning!! " -Cody Baird
« Reply #21 on: June 13, 2020, 10:43:43 AM » |
Ok, a follow up observation FWIW.
I have recently replaced my timing belts for the second and most certainly the last time. First time was at 80,000 miles and due to the fact my bike is a ‘97. The first belt change I used Gates belts bought locally for like $20 each. They fit great and still looked new new when I replaced them replaced them at 170K.
So, you ask, why did I replace them? Well that’s a good question. I almost didn’t lol. But, I wanted to replace the tensioners and springs. The last time I was in there to seal the one bolt that leaks I wasn’t happy with one of the tensioners, it did turn real smooth. And because a while back I scored a killer deal on new OE tensioners and Honda belts from a member here, I thought, what the heck these will last longer than I will so I changed them.
Ok, now the reason I’m m posting. The Honda belts seemed to go on a bit harder. They were tight. The new springs didn’t even seem like they could even do anything. Before I tightened the mounting bolts I pressed the tensioners away from the belts (increasing slack). And just let them with their springs decide where they wanted to be. I did that two or three times trying to get a bit more slack in them but I had to just torque them as they were and see what happens.
So after hand turning and triple checking my marks I fired up the engine and all was well. Fast forward to today. I decided after a couple thousand miles to open it up and see how everyone was doing. To my delight the belts seem to have relaxed just enough. Perfect slack, and I did that test twisting them 90 degrees. All was great.
So. If you are replacing with Honda belts it might be good to know
« Last Edit: June 13, 2020, 10:45:16 AM by Chrisj CMA »
jnicks01
« Reply #22 on: June 14, 2020, 05:21:13 AM » |
Follow up. So that was easy. Took my time and followed a few manuals during the process. No PO has been in there as the pink-ish thread locker was still in tact. Belts looked good as did the pulleys. Only 36K on the clock anyways. New belts and set the tension by allowing the springs to set it. Checked marks about 20 times. All good. To others worried about this project. Don't be.
indybobm
« Reply #23 on: June 14, 2020, 06:18:07 AM » |
Do you think that the belts were stiffer because of the way they were made or because they could have been in the supply system longer?
« Last Edit: June 14, 2020, 06:22:50 AM by indybobm »
« Reply #24 on: June 14, 2020, 06:37:23 AM » |
Dunno. They seemed a few microns shorter
mello dude
Dayton Ohio
« Reply #25 on: June 14, 2020, 09:23:37 AM » |
Follow up. So that was easy. Took my time and followed a few manuals during the process. No PO has been in there as the pink-ish thread locker was still in tact. Belts looked good as did the pulleys. Only 36K on the clock anyways. New belts and set the tension by allowing the springs to set it. Checked marks about 20 times. All good. To others worried about this project. Don't be. Where did you get your belts?
jnicks01
« Reply #26 on: June 14, 2020, 05:45:35 PM » |
I don't recall exactly, but it was probably amazon or summit racing. I bought them quite a few months back when I was getting all my fluids and other parts. Just Gates belts. Nothing special.
