December 30, 2025, 08:07:30 PM *
Author Topic: Need brass bushing for turn signal switch  (Read 1511 times)
vanagon40
Greenwood, IN
« on: May 31, 2020, 04:42:47 PM »
I need the brass bushing that goes under the turn signal switch actuator. It is under the washer (circled in red), under the actuator, and above the plate. The actuator slides on top of and around the bushing.
The bushing is not sold invididually. I hate to buy a new (or even used) entire switch. If someone has a damaged switch, I need only the bushing. I was cleaning mine today and did not realize there was a bushing under the actuator. The bushing fell out (I did not realize that at the time) and I cannot find it.
If you have one to sell, great. If someone has a spare that I can borrow (so I can fabricate my own), I will pay for postage and promptly send the original back. Or if someone can even give me measurements?
I really need some help here. What I thought was going to be a simple project now has me grounded.
PM or email me at [my member name] @ either gmail or yahoo [the last character in my name is a zero, not a capital "oh"].
HELP (and TIA).
vanagon40
Greenwood, IN
« Reply #1 on: May 31, 2020, 05:36:48 PM »
The good news is I'm back on the road. Managed to improvise with small piece of rubber/plastic hose and a small washer. Works--not too smooth--but works.  Still need a brass bushing.
rug_burn
Brea, CA
« Reply #2 on: May 31, 2020, 08:20:25 PM »
What would be the ideal dimensions for that bushing, keeping in mind the necessary play for this part?
...insert hip saying here..
da prez
Wilmot Wi
« Reply #3 on: June 01, 2020, 12:10:47 PM »
PM me an address.  I have one ready to ship to you.
             da prez
vanagon40
Greenwood, IN
« Reply #4 on: June 01, 2020, 02:06:22 PM »
PM sent.
da prez
Wilmot Wi
« Reply #5 on: June 02, 2020, 05:54:58 PM »
Sent today by snail mail.
         da prez
« Reply #6 on: June 04, 2020, 01:28:40 PM »
I'm wondering a bullet casing, split open and made flat. Some other kind of circular punches for the outer/inner diameter.
vanagon40
Greenwood, IN
« Reply #7 on: June 04, 2020, 05:49:18 PM »
Not to worry about trying to fabricate something. This showed up in my mailbox today. da prez is da man.
« Reply #8 on: June 05, 2020, 08:50:00 AM »
Great work da prez!   cooldude
Nice when Valkers help other Valkers.
Keep an eye open for that missing piece, you know you will find it. Then wounder what's this from?
RonW
Newport Beach
« Reply #9 on: June 05, 2020, 11:03:49 AM »
I wouldn't take the thumb lever assembly apart. You can lube it adequately with the parts intact and without the risk of loosing parts. At the most I just tighten down the screw a smidgen. I've never lost a part.
2000 Valkyrie Tourer
rug_burn
Brea, CA
« Reply #10 on: June 06, 2020, 03:49:18 PM »
Your basic "hat section bushing"
    I need to check mine, too;   been kind of stiff for  about 10 years now...
da prez
Wilmot Wi
« Reply #11 on: June 06, 2020, 04:06:19 PM »
  I was going to take measurements for a drawing . I could turn them on the lathe incase someone else  looses one. To busy of a week.
                                            da prez
