December 30, 2025, 08:07:34 PM
coils and wires
Topic: coils and wires (Read 1384 times)
rafalc
Central NJ
coils and wires
June 03, 2020, 09:50:04 AM »
Just wanted to find out if there is any obvious way to figure out if I need new coils or wires (gets pricey to replace all). The bike is a 1998 with 11k miles, probably original coils and wires. As far as I remember it was starting and idling fine before I started the project.
Any advice?
Re: coils and wires
June 03, 2020, 10:27:29 AM »
Don’t try to fix something that isn’t broken. I have a ‘97 with 170 thousand miles and it’s got original coils and wires
Re: coils and wires
June 03, 2020, 10:28:35 AM »
coils and wires are bullet proof. only thing with wires which is very extremely rare is the resistor in the plug end could go bad. again very very rare.
test the coil and wires per manual, write down results for base line.
Re: coils and wires
June 03, 2020, 06:13:18 PM »
The coils failed on George. But then he's blown and has been for 30,000 miles. Likely that's coil abuse. There was virtually no spark. I have never seen an engine run with such a nothing spark. I replaced them with more powerful VTX coils, and he fired right up. Also installed a Dyna3000 and a pressure sw with relay to ground the D3000 retard wire when boost hits 4#. And installed a boost meter. Yes I did test the signal generators and the voltage specs at the coils, per the shop manual. Used a peak voltage adapter, documented it all - posted the tests here. Everything up to spec - except the anemic spark. I also picked up this really handy and inexpensive spark tester, online.
https://www.amazon.com/Deal%E3%80%91OriGlam-Adjustable-Ignition-Circuit-Diagnostic/dp/B06X9RC3PF/ref=pd_sbs_86_img_2/133-0320539-7602363?_encoding=UTF8&pd_rd_i=B06X9RC3PF&pd_rd_r=c61335e4-3b80-40e1-beeb-ff055dea3759&pd_rd_w=R466s&pd_rd_wg=YYXNN&pf_rd_p=5cfcfe89-300f-47d2-b1ad-a4e27203a02a&pf_rd_r=E6VG83CQW0QWZHK0G7AZ&psc=1&refRID=E6VG83CQW0QWZHK0G7AZ
The thread with the discussion on my ignition troubles is here -
http://www.valkyrieforum.com/bbs/index.php/topic,108849.0.html
Last Edit: June 03, 2020, 06:22:52 PM by MarkT
Re: coils and wires
June 03, 2020, 06:37:37 PM »
Quote from: Chrisj CMA on June 03, 2020, 10:27:29 AM
Plus 10
=> InZane XXV
