August 19, 2025, 08:20:13 PM *
Author Topic: Carburetor gasket adhesive  (Read 1107 times)
studlly 64
Norwood, Mass
« on: July 09, 2020, 11:41:00 AM »
I'm in the process of changing the gaskets on the carburetors, is gasket adhesive required for the new gaskets?
1998 ST
sixlow
St. Augustine, Fl.
« Reply #1 on: July 09, 2020, 02:05:44 PM »
No, the only gasket that should be adhered is the bowel gasket. that being said I have done my earlier rebuilds without it and they didn't leak. After getting great advice from Attic Rat I started using a very small thin line on the bowel side only using a curved syringe.
« Reply #2 on: July 09, 2020, 10:54:42 PM »
I didn’t replace my O rings and used Permatex non hardening gasket maker for petroleum distillates.
« Reply #3 on: July 10, 2020, 04:21:08 AM »
When we sent a set of carbs to the dealer to get rebuilt I had to check. We knew some of  vent passages were clogged. So upon receiving the carbs back I popped one bowl off go see if the passage was open. It was. There was no adhesive gluing that bowl on. It popped right off clean as a whistle and went back on dry and didn’t leak.
« Reply #4 on: July 10, 2020, 02:30:54 PM »
I have had the bowls off about 20 times due to re-jetting/tuning, still with original gaskets, zero leakage, never removed the gaskets from the bowl.
Jims99
Ormond Beach Fl.
« Reply #5 on: July 11, 2020, 04:56:57 AM »
With o-ring style gaskets, you should not need any adhesive. I have never used it and never had any leaks. I have used a slight bit of grease to hold them in place while putting them together with never a problem. Unless the gaskets get hard or break, they should last for many years of pulling apart and back together.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
