December 30, 2025, 04:35:07 PM *
Author Topic: Crush Washer Question  (Read 1460 times)
« on: July 17, 2020, 10:02:01 AM »
I replaced the clutch line, master cylinder and the slave cylinder on my 2000 Interstate.
Where the bleeder goes into the slave cylinder is leaking like crazy.
I ordered a new banjo bolt and new crush washers.
If you look closely at the washers the two sides are different:
One side is totally flat
While the other side is more rounded.
My question is:
Which side goes against which surface?
« Reply #1 on: July 17, 2020, 10:58:12 AM »
It doesn’t matter. You can buy them at ACE, HD, and Lowes. Bring the old one and match the size.
RonW
Newport Beach
« Reply #2 on: July 17, 2020, 11:04:42 AM »
Just a question, but are you using two washers?
2000 Valkyrie Tourer
« Reply #3 on: July 17, 2020, 11:49:49 AM »
I've always put the flat side to the banjo.
Gideon
Indianapolis, IN.
« Reply #4 on: July 17, 2020, 11:58:58 AM »
I don't think it matters.
« Reply #5 on: July 17, 2020, 12:43:01 PM »
Yes
« Reply #6 on: July 17, 2020, 12:47:36 PM »
That's what I thought I did.
I haven't taken it back apart to see yet, I was waiting for the new washers to come in.
I'm not sure if it does or not, but I figure their has to be a reason why the two sides are different.
« Reply #7 on: July 17, 2020, 04:57:54 PM »
Most likely it's a function of the manufacturing process.  They are likely stamped out of sheet metal, causing the rounding.  Ordinary flat washers are the same.  I always put the rounded edge towards the fasterer, and the square (or burred) edge towards the thing I'm fastening.  It looks better, IMO, and the sharp edge of the washer can't cut anything.
regular stainless flat washer:
« Last Edit: July 17, 2020, 05:03:11 PM by Gryphon Rider » Logged
6adan
Zip City, Alabama
« Reply #8 on: July 19, 2020, 08:23:08 AM »
  You can also use the old washers by heating them cherry red and dropping it in water.
1970 CB750JDM, 1975 GL1000, 1979 GL1000 semi cafe, 1979 CBX, 1995 GL1500 SE, 2008 GL1800 trike. Several more not running yet.
