December 30, 2025, 04:35:54 PM *
Author Topic: Fuel sending unit leaking!!!  (Read 1042 times)
larue
Clermont,FL
« on: July 29, 2020, 05:16:27 PM »
Hi all , like I mentioned before in another thread I had to change the O ring on my interstate fuel Sending unit. Now when I put it back  And  secured the sending unit plate on the tank with the o ring in there of course, I get a leak around the plate, the leak gets worse and gas gashes out when I open the gas cap and slower  when I close lock the lid. very strange , I tried it several times same results, am I over tightening it, am I missing something!!
Note: I’ve had this tank for years never an issue. Thank you all in advance
« Reply #1 on: July 29, 2020, 05:30:09 PM »
Did you get the stud fixed ? Is the vent line plugged or kinked ?
larue
Clermont,FL
« Reply #2 on: July 30, 2020, 10:44:29 AM »
I did get the stud fixed, however this happened before that while the tank was on the bench and  before breaking the stud. I’m scratching my head
« Reply #3 on: July 30, 2020, 10:52:40 AM »
With the knowledge that you had twisted off one stud already I would have to say that the leak is because you are overtightening the nuts.
