August 19, 2025, 05:55:07 PM *
Author Topic: Cobra 6 into 6 and boots  (Read 1437 times)
AwesomeDad
TN
« on: August 18, 2020, 08:57:12 AM »
Tried searching, but cant seem to find what takes boot marks off exhaust?
JJ
« Reply #1 on: August 18, 2020, 09:49:44 AM »
I use all metal polish. Pretty much the same as aluminum polish pretty easy if done while warm. It’s easier to learn how to keep yer feet off the pipes
da prez
Wilmot Wi
« Reply #2 on: August 18, 2020, 10:04:12 AM »
MEK.  Do it cold.
         da prez
« Reply #3 on: August 18, 2020, 10:33:35 AM »
Goof-Off....done when cold. Then wash off and polish.
« Reply #4 on: August 18, 2020, 11:50:29 AM »
Smart n final sells “Carbon Off”. Works for me.
AwesomeDad
TN
« Reply #5 on: August 18, 2020, 08:10:59 PM »
I believe it’s when I put the kick stand down my heel is touching it’s only on the left side...
JJ
« Reply #6 on: August 18, 2020, 09:04:56 PM »
JJ
You, along with probably every rider on this board has done it. You will find away to train yourself not to. I keep my pillion foot boards folded down on my Interstate to keep me from doing it. On my Standard with OEM pegs I have to be more mindful. A real fine steel wool used easily works well also.
« Reply #7 on: August 19, 2020, 04:24:00 AM »
Try using the toe of your boot to put stand down also.
« Reply #8 on: August 19, 2020, 04:50:36 AM »
And sometimes the kickstand assist lever gets a little bent, making finding it with your foot more difficult.
Take a pipe or PVC tube or something and stick it over the assist lever and bend it where it is easier to reach.
EDIT:  But not so it drags in hard left turns.
« Last Edit: August 19, 2020, 10:42:08 AM by Jess from VA » Logged
AwesomeDad
TN
« Reply #9 on: August 19, 2020, 09:27:24 AM »
Great idea I will try it.
JJ
Gregory Scott 16248
Pittsburgh, PA. Cranberry TWP.
« Reply #10 on: August 19, 2020, 07:36:56 PM »
JJ
Use oven cleaner on your pipes to clean off boot marks.
VRCC#16248
1999 Interstate with Lehman Predator Trike Kit
2008 Goldwing L3 with Motor Trike Kit
2009 Kawasaki Vulcan 900
2021 Can-am F3 Limited Chrome Edition
2019 Forrest River Trailblazer 30' Toy Hauler
